Rocker keeps coming loose.
It first happened when my friend helping put the heads back on after a cam swap didn't push the pushrod all the way down, meaning the lifter wasn't sitting on the cam all the way, which means the rocker didn't get tightened quite to spec, and it was turned sideways when we pulled the cover. We pushed the pushrod all the way down, and retightened the rocker. Drove it fine for a few weeks, and I heard a ticking last night. Pulled the valve cover and the same rocker is loose again. Should I just throw some red loctite on and hope for the best?
OP are you sure the threads are fine in the head?
Somthing IS up if it happned again, in not just a random thing it happened in that spot after the 1st issue. I'd look at the bolt close it its stretched under the head, or something up with it. take the rocker stand off and look at it closely, it might be cracked or somthing, form running with it not set right. Same with the cam,lifter or lifter tray, but hope its on top of the head for a easier fix.
