HELP!!! Car is consuming coolant and has a knock!!
As far as iron blocks go, I'm happy with mine. I bought my LQ4 as a complete engine, but i wish i had just bought a shortblock and installed the LS3 top end from the beginning. A complete LS3/L76/L99 top end cost less than a FAST intake alone and makes a lot more power than a FAST with stock 243's or 317's.
So you have a lq4 6.0 iron block with ls3 top end?
When are you going to get that head off for inspection?
make sure theres no scoring on the cylinder wall..replace the piston, re-hone the cylinder if you cant see cross hatch, helps for new piston rings to seal. did this exact thing when i chipped a piston on my 6.0 lq4.
make sure none of the valves in the cylinder head are leaking by spraying brake clean in the intake side, and exhause side of that cylinder..reason i say brake clean is because its thinner than water and will tell you if your valves are leaking.
