Valve Float?
Me measuring the primaries. My spark plug wires barely fit in between these things
I have had underperforming engines before, but usually the power peak lies close to the peak I would expect for that cam profile. MS4 is a monster stick IMO even on a 383, and should be sidnificantly higher.
Also these super high open pressures over 400lbs will over time chew the valve stem tips up from an improper wipe pattern on the tip of the valve. This is why Brian Tooley recommends no more than 400lbs of open pressure on stock rockers. With a stock rocker it is so light that even with some of the most aggressive hydraulic lobes available today it is still plenty sufficient for controlling them.
Also more than 400lbs open pressure with aftermarket rockers on 5/16" push rods will start to "pogo" the push rod as it deflects from too much over the nose weight and too much spring pressure. I know you don't have aftermarket rockers, but it's good information to put out there.
I might of missed it but what intake manifold are you using?
I agree the headers are choking it and not allowing it to pull to the rpm peak it should with that cam. I don't see any valve float in that graph either.
No one asked what kind of dyno was this? SAE correction factor being used?
What ICL did you install the cam at or is it straight up? If it hasn't been degree'd in with a degree wheel I'd do that and see if it's correct.
humans ? Wtf are th0se?
