California only Mobil 1 engine oils?
Is it an LS1 powering that industrial equipment, or hell any other passenger car engine? NO? Well then WTF does that have to do with anything?
Car engines have an engine producing soot/carbon, ingesting air through a limited size filter with a relatively small sump capacity and tiny oil filter. Automotive oil is generally dirty before it is worn out. In some big industrial application it can have bigger finer filters massive sump capacity, plus who is to say a basic dino oil would actually do harm???
Do you honestly think taxi companies use synthetic or retire vehicles before 300K? You would be very wrong on both counts. Sure a taxi company here or there will use a synthetic when paid to by an oil company making a commercial but otherwise they maintain them cheaply as possible and M1 is NOT part of that equation.
LS1Tech Premium Sponsor
They likely pulled some of the ZDDP content (anti-wear agents) in order to make it more California emissions friendly.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
The sad thing about it is what happens in Calif. seems to happen everywhere
sooner or later.
eg: The new fuel milage standards do not have a C.A.R.B. standard for Calif cars
they will all be CARB compliant.
sooner or later.
How about a bunch of words....my Z28 has 312,000 on Mobil1. lol.
Frankly, I have yet to see an engine fail because of the type of engine oil used. I've seen engines fail from having too little oil, too much oil, the completely wrong viscosity...but never because of using a certain brand over another.
How about a bunch more words...your Z28 woud've lasted the same amount of miles regardless of brand of oil that you used.
You truely don't have a Clue do you?
#32
The people here on this performance minded website are not going to be the bulk of the people hitting 300K. long distance commuters and fleet vehicles do it all the time it is nothing special atall, though apparently since you think all engines die sooner than that you are a bit "special" yourself.
