Ed Curtis Cam / AFR 205 Install / Results
I might get a wild hair up my *** though and take her to Donaldsonville in the next month or so. If it (the rear) blows, it blows. I'll just build it bigger and stronger.
Here's a thread about it from another site. Sorry if it's against the rules but I feel it's good info.
http://www.yellowbullet.com/forum/sh...d.php?t=496882
One full turn should have put me right at .047 for preload. I was surprised to say the least that I needed a 7.4 PR. I was really thinking I'd need at most a 7.375 being the heads are 59cc. If I had gone with the Cometic .040 I would have for sure. Geoff steered me away from that though as he was worried about my dynamic compression. I'm right at 11.7 static as it is.
For noise it's not bad. It isn't so much a sewing machine as its the valves. Ed's cams have, for the most part, ridiculously fast ramp rates. I can def hear them closing, that's for sure.
I'm really happy that you got the build done and are happy with the results. I'm going out on a limb here, but I think you're going to be even happier on the 18th. Those Ed Curtis cams are pretty bad ***, especially when you let him custom spec one to meet your mods and goals. Make sure you keep us posted on the dyno numbers. She's going to be stout.
Well, dyno day was split in two due to a double booking, lol.
Anyways, great time with Geoff over the past two days; guys incredible to say the least.
Best run before the clutch gave out was 452rwhp and 417rwt, sae corrected, on his dyno jet. I'm happy to say the LEAST!
Geoff says theres definately a bit more in it, after I get a clutch worth a ****, and a set of 42# injectors that ALL work. Found out one was dead today, so the pulls were done with my stock, what, 28.8's?
What a blast to drive now!
Anyways, graph, vids, and everything else coming in the dyno section in a few days.
#40
I know. I'm so pissed about that dead injector.
Shopping for a new clutch too. I'm thinking about going with the sprung 6 puck from ACT. I haven't heard **** about it, and it's reasonably priced. ACT treated me great on an AWD Eclipse back in the day....
Oh yeah, and that graph up there... That's the difference between running a dirty MAF and a clean one. Cost me 13hp. I learned you really can't just spray them clean. Once you pop the ends off you'd be surprised what you missed.
