Flaw in block. Will this affect it?
Old Oct 3, 2012 | 02:22 AM
FlipediS's Avatar
Default Flaw in block. Will this affect it?
So i started tearing down an lq9 i bought that had 75k miles , For my 408 build. As i pull the valley cover i seen this defect in the block. looks like a crack... i can feel it on the under side as well , but feels very solid. Not sure to just leave it.. To cut it out? or if this will effect anything latter? let me know what you think... thanks.
Old Oct 3, 2012 | 06:02 AM
parks450's Avatar
That looks notmal if im looking at the correct spot. If you have ever had a gen 3 block apart before they have alot of casting imperfections so nothing to be worried about.
Old Oct 3, 2012 | 08:06 AM
velox65's Avatar
I agree, casting flaw. I wouldn't be worried by it.
Old Oct 3, 2012 | 10:26 AM
Randy WS6's Avatar
It look like the oil drain back port, no big deal. Before i built my engine i took a die grinder and removed all the ruff casting edges to smooth the flow of oil. And Ive seen allot worse than that from the factory , you will be fine.
Old Oct 3, 2012 | 10:45 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Agreed, I wouldn't hesitate to run that one!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 3, 2012 | 01:10 PM
FlipediS's Avatar
That's what i figured, thanks
