step closer to H/C build being put together..
Old Oct 17, 2012 | 08:10 PM
  #41
stangkiller2005's Avatar
Originally Posted by IllusionalTA
Make sure to check piston to valve clearances, and you have the appropriate springs and their installed/shimmed at the correct heights!
I just wanted to get the bang for buck outta setup. So far the prc 675 springs seem to be the ones.
Old Oct 17, 2012 | 08:18 PM
  #42
IllusionalTA's Avatar
Yea, most are pretty happy with them, I ran the xtremes. And floated the valves.. So I'm runnin PAC now.. I never expected my cobbled together setup to run as well as it does, but it's the details..
Old Oct 17, 2012 | 11:14 PM
  #43
Defenaltly thats why i am trying to do the little details to.squeeze the hp.out of my small setup.
Old Oct 18, 2012 | 12:57 AM
  #44
and you would leave heads as they are?
Old Oct 18, 2012 | 05:12 AM
  #45
Well me personally no.. But your not interested in measuring all day.. So keep it simple, I can guarantee I'd be fly cutting..
Old Oct 18, 2012 | 11:13 AM
  #46
yea no fly cutting for me. haha. maybe the next motor. i do want to mill them to boost compression though.
Old Oct 25, 2012 | 01:34 PM
  #47
so we can add a yank ss 4000 stall with a 2.5str to the mod list. im stoked. just picked it up off a member.
now that im starting to think. wow my car is going to be completely different beast.
dam i want to bump compression on my car.
question for you fellas
lets entertain the idea i do have time to let the car sit and wait for the correct push rod length to get here.
what mill and gasket would you guys use with this cam? i know it will clear without fly cutting with the mill and cc i suggested above. i do not think clay would be needed. so i can put it all together. order them after i measure after had installed heads along with everything else minus valve covers rockers of coarse.. installing them whenever correct length arrive.
Old Oct 30, 2012 | 03:46 PM
  #48
hey guys.
finally got a deal on an ls6 intake i can afford. question will i be able throw everything from my old 98 intake onto this ls6 intake? the one i got is coming bare.
Old Nov 5, 2012 | 03:28 PM
  #49
dont all everyone answer at once lol.
well pac springs good to 670 will help keep the valve float from occurring.
i picked up some arp hex head bolts for 120 shipped. do these get torqued down the sameway as the stocks?
still need to pick up gaskets and push rods. guess ill be leaving heads alone and throwing in stock mls gaskets.
Old Nov 5, 2012 | 03:50 PM
  #50
Make sure you shim them correctly for the lift your running... Arp bolts require a 3 step process I.e 25, 45, 75 ftlbs in the recommended pattern by GM
http://arpinstructions.com/instructions/134-3609.pdf
Old Nov 5, 2012 | 04:00 PM
  #51
awesome thanks bud. if my springs come with the seats and retainers will the seat be considered the shim? or do i need something else? ive never shimmed before. the lift is 595' 644'
Old Nov 5, 2012 | 04:05 PM
  #52
It will have to be factored into the installed height.. Yes.. But you still have to measure your heights and add accordingly to achieve your desired installed heights
Old Nov 6, 2012 | 03:38 PM
  #53
More measuring lol. I think i need to fly u out here haha. Im not even sure what my desired measurement would be. I just want the car to run as it should so that she makes some power. I think 80% of people who do setups around here dont measure.for that :/ im embarised.
Old Nov 6, 2012 | 04:54 PM
  #54
80%? More like 95% don't be embarrassed, sadly brand new heads come out the box setup improperly for the cam being used.. Don't be embarrassed.. It's a great learning experience., what cam u running? What valve spring etc.. What locator you have? How thick etc.. Lets get it figured out for ya
Old Nov 6, 2012 | 05:37 PM
  #55
LilJayV10's Avatar
Hell even most machine shops don't know how to set up a set of cylinder heads properly. I found that out that hard way. My install height was suppose to be 1.72 and it was at 1.81. After some serious valve float and the inner springs pulling the valve seals off I realized something was wrong. After that I learned how to measure install height, shim accordingly, etc.
Checking things like that makes a difference in a car that runs OK and a car with the same parts run great.
It's much easier to measure this stuff before you put the heads on the car. I however didn't have that luxury.
Old Nov 7, 2012 | 12:19 AM
  #56
alright so here is the mod list as of now valvetrain wise.
tr trak cam 235.16/232.70 .595" .644" 112lsa
the spring kit is Pac-1208x says on the box
installed 482@1.800
open 482 @1.110
rate 460
coil bind 1.000
RETAINERS is PAC-r335
diameter a 1.300
diameter b .940
diameter c .680
lock angle 7
SEATS Pac-s129
diameter A 1.270
Diameter B .680
diameter C .520
heads are 799 casting with minor hand porting. no mill. i wanted to but will probably leave alone. possibly go with .40 gasket but will also probably leave it stock thickness.
Old Nov 7, 2012 | 08:39 AM
  #57
Sales@Tick's Avatar
I have a cam that would also work very well with what you're trying to do.
It's specs are 234/240 .61x"/.58x" 113+4. http://www.tickperformance.com/tick-...r-ls2-engines/
Old Nov 7, 2012 | 11:40 AM
  #58
I already have the cam i just stated above. Not really trying to go through hasel of selling and getting another one. Also i have an ls1. Says that cam specifically for ls2?
Old Nov 7, 2012 | 01:31 PM
  #59
Ls1/ls2 cam same ..
Old Nov 7, 2012 | 01:59 PM
  #60
Ls1/ls2 cam same ..
I posted what you asked for above.
