New member ls-1 or 6.0??????????????
Old Oct 7, 2012 | 07:49 PM
98 ls-1's Avatar
Default New member ls-1 or 6.0??????????????
hello guys . i have a knocking 198.000 mile 98 ss z fig i spun a bearing still runs. FIRST QUESTION (remember on a budget kinda)should i rebuild factory motor or 6.0 both are gonna run me round 4 grand just dont know bout 6.0 working on ecm and oil pan .ect i know it will make more power i found one at local shop for $350 in a wreak van looked at stroker kit at tsp they $2200 i also plan on spraying the **** out of it. i can do the work just in dark on these motors any info would br greatly appreciated
Old Oct 7, 2012 | 07:55 PM
wildcamaro's Avatar
I would rebuild the ls1 you already got...this is because I just don't like iron blocks in fbodies just because of the weight difference, if you do go with a 6.0 you can at least recoup some of the money from selling your old ls1...if you want it to handle keep the aluminum block ls1, but if all you want is straight line performance go with the 6.0...you can't lose with either motor! Now if you find an lq9 (high compression) 6.0 that is the motor to start with (ls2 aluminum 6.0 is top of the hill though as far as third gen LS motors)
Old Oct 7, 2012 | 08:22 PM
98 ls-1's Avatar
thanks i really would like to spray it bout 175/200 shot looking for a 6.90 1/8 mile pass with a turbo 350 trans and iam 38 yo just incase some say this kid is stupid
Old Oct 7, 2012 | 08:51 PM
InsaneDomestics's Avatar
No replacement for displacement... If you found a 6.0 for $350 I'd hop on it. Use the pan and acc. from your ls1 and drop it in.
People are making some ridiculous power on the stock crank so you could save yourself some money there and just get a good set of rods and pistons. Stud it all out and with a good tune you should be set...
Old Oct 7, 2012 | 10:12 PM
mark21742's Avatar
Since I run one I'll throw a vote in for the 6.0l. 100 more pounds than the stock ls1, but if you feel the need you can drop that weight back down with a tubular cross member and lighter front suspension.
Old Oct 7, 2012 | 11:02 PM
badazz81z28's Avatar
My take is if you plan to go for big power or boost go iron. If your not making considerable more power than the aluminum LS the extra weight will suck! My front end raised about 3" from swapping iron out for aluminum. It may only be an extra 100lbs or so, but it seems like so much more.
Old Oct 8, 2012 | 05:20 PM
98 ls-1's Avatar
iam leaning more toward a stroked 6.0 only worry is my ecm being able to work on the 6.0 and injectors,crank sensor,being a 98 model i know it doesnt have the techology that a 02 has
Old Oct 8, 2012 | 05:24 PM
LT1TransAm's Avatar
ecm can be pinned if needed but its really all in the tune.
Old Oct 8, 2012 | 06:03 PM
IllusionalTA's Avatar
It'll drop right in.. Enjoy!
Old Oct 8, 2012 | 06:16 PM
wildcamaro's Avatar
I didn't realize you said you could get the 6.0 for 350 bucks...jump on that! You could swap on your ls1 heads and be making right around 10:1 compression...
Old Oct 8, 2012 | 09:03 PM
ace32x's Avatar
ecm should be a plug and play for the ls1 and the 6.0, if your not making big power i would suggest staying away from the iron block. look into a 383 stroker with some 11:1 pistons if your looking to spend that much.
Old Oct 22, 2012 | 06:22 PM
98 ls-1's Avatar
gonna buy some good stuff for ls1 i guess ill try to post some pics of build as i go i may need some help along the way THANKS GUYS FOR THE INFO
Old Jan 1, 2013 | 04:12 PM
98 ls-1's Avatar
HELLO GUYS JUST WANTED TO LET YOU KNOE I HAVE CHOSE TO GO WITH www.cmengines.com THEY WILL DO MY LS1 FOR LESS THEN 2 GRAND THE CHEAPEST I FOUND AROUND LOOK AT THERE PRICES REALLY GOOD FROM WHAT I SEE DOES ANY BODY KNOW OF THIS GROUP I STILL PLAN ON BUYN A TEXAS SPEED CAM KITWITH SPRINGS WILL LET YOU KNOW AS I GO THANKS AGAIN GUYS
Old Jan 1, 2013 | 04:56 PM
wildcamaro's Avatar
Good choice, the front suspension will thank you..
