Guesses on how much my 347 will pump out?
Old Apr 9, 2004 | 08:11 PM
Scoobie's Avatar
Default Guesses on how much my 347 will pump out?
What do you think she will make? its almost done, will know soon.
LS6 Block 3.903 Bore ( 347 ) 11:53:1 Compression
- Lunati 4340 Crank
- Lunati +12cc Forged Pistons
- Lunati Pro Billet Connecting Rods
- King Bearings
- ARP Main Stud Kit
- ARP Rod Bolts
- Comp Double Roller Timing Chain
- LS6 Ported Oil Pump
- TTP Equalizer Camshaft ( Similar to G5X2 in size ) going 110.5 LSA
- Meziere Electric Water Pump
- Absolute Speed Stage 2.25 6.0l Heads ( around 320 intake at .600 )
- Absolute Speed Ported LS6 intake
- Absolute Speed 78mm Throttle Body
- TSP lid
- Breathless Performance Maf ends
- Kooks 1 3/4" to 1 7/8" Steepd Stainless Headers, Off road Yipipe
- Hooker Catback
- ASP crank Pulley
M6 transmission, stock 10 bolt ( temporary ) with 3.73 gears and a Ligenfelter 3.5" Aluminum Drive shaft.
Old Apr 9, 2004 | 08:15 PM
Scoobie's Avatar
Also, how high do you think i will be safely able to rev it up too? Is 7,000 Un Realistic?
After breaking it in, i will be adding a 100 - 150 shot.
Car will not be a track *****. I wanted to build an affordable, strong street car that should put most LS1's and 03 Cobras in my rear view. I cant wait!
Old Apr 9, 2004 | 09:07 PM
gomer's Avatar
With the good crank, rods, and other stuff.. I'd say 7,000rpm is safe. I'm guessing that you will dyno around 455rwhp and 415rwtq with the belt on... add 10 if you take the belt off. I had ported MAF ends on my car and had to take them off because they messed with the A/F curve really bad. It actually made more power with the stock ends on it. Let us know how it turns out, I'm anxious to see how some expensive heads do with a cam that big.
Old Apr 9, 2004 | 11:29 PM
Scoobie's Avatar
Thanks Gomer, im hoping a little more then that but not by much. I want 470 at 6600. dont know if it will happen though. A lot of stock bottom end cars hitting 455 or higher. Im running a full point higher compression, every bolt on, perhaps the best headers, perhaps the best heads and extremely light rods. It should be finished and tuned within 2 weeks. Trying to get it in for tuning is taking some time
Old Apr 10, 2004 | 12:03 AM
verbs's Avatar
With all that stuff on there why not throw on a cutout to squeeze out a few more ponies?
I agree with Gomer, ditch the MAF ends. With that compression on a stock 10 bolt I'd say 460-465 rwhp is doable with some aggressive tuning.
Old Apr 10, 2004 | 06:13 AM
Fred99LS1's Avatar
Also you might of gotten them but I didn't see bigger injectors in your list of goodies. I just got my car done & the stock injectors were maxed out at 6200 rpm's on my 99. I ended up having to have some 30 lb injectors put on. You may need a bigger injector if you didn't already have that in mind, Fred
Old Apr 10, 2004 | 06:51 AM
offaxis's Avatar
I would think you can hit the 470 # or even more you want but you will need a really good tuner and I think you might need a cutout. Paying a pro to tune your car is always worth the money .Im just not sure about that cam not having all of the specs on it. Your 347 really doesnt make much extra power but it will last . I think the added compression is only worth 8-10 hp. I hope you picked up some 30# injectors too. Good luck with the setup and feel free to post more about the cam so we can make more accurate guesses .
Keep us up to date
Old Apr 10, 2004 | 09:08 PM
John02SS's Avatar
Your gonna make me spend money damn you Scott! I can't wait to see it. When you gonna pick it up, since plans changed. When time comes let me know as I might still be game to make the trip with ya!
Old Apr 10, 2004 | 10:00 PM
Beast96Z's Avatar
Don't make me drive to Florida to out run you! Dallas was far enough. You should have a pretty stout set-up. Hope it turns out like you want.
Old Apr 10, 2004 | 10:08 PM
BOWTIE's Avatar
Scoobie, not trying to start any debates here, but what made you decide to go with the stock stroke? Since you were buying a new crank, rods, and pistons it would have been the same price to go ahead and stroke it a little which theoretically would make more power. Just curious.
Old Apr 10, 2004 | 10:23 PM
pdd's Avatar
pdd
sounds like a mint setup u have there. ill say 470
Old Apr 11, 2004 | 12:10 AM
DONAIMIAN's Avatar
I say 470 is doable with that EWP and the other mods, but your tunner is gona be your best friend.
Old Apr 11, 2004 | 12:19 AM
DONAIMIAN's Avatar
and you should have no problem spinning to 7k maybe even 8k depending on your rods and rod bolts. Ofcourse valvetrain also.
Old Apr 11, 2004 | 06:15 AM
KGSloan's Avatar
i think it should dyno very well. it sounds like a killer setup. i'll guess 475rwhp
keep us updated
Old Apr 11, 2004 | 07:13 AM
kumar75150's Avatar
Old Apr 11, 2004 | 09:00 AM
apexman's Avatar
Originally Posted by kumar75150
Sounds like an easy 450+ and around 420Tq. Wonder how high in the RPM the car will pull to? Bet it goes at least to 6800 or so. You should be fine shifting it up high in the revs if it is just a drag car.
Gulfport Ms.! I actually went to school in Long Beach. That is where I grew up. Maybe I will see that orange beast sometime. I have been wanting to bring my car to the Gulfport dragway. Used to go up there now and then with my old '67 RS 327.
Good luck,
Derek
Where are you going to be dynoing?
Old Apr 11, 2004 | 12:14 PM
Scoobie's Avatar
Actually, the reason i went with that crank is because i got the crank, pistons, rods and block as a package deal with no tax. I bought it off a shop owner who was going to use it as his own. Yeah, would love to have a stroker but the machine work was already done and this is mainly a street car, not a track car. Thanks for all of the replies. I will keep everyone in the loop. I do have a fine tuner btw and as of the moment i am using stock injectors. Not by choice though, but this thing cost me a pretty buck. Beast good to hear from you, bring it on man John, i will let you know for sure.
Sc00bs
