Pulling heads, then leaving them off for a month
Old Mar 6, 2003 | 11:33 AM
Constrictor 98TA's Avatar
Default Pulling heads, then leaving them off for a month
Is there anything special I should to to prevent rust or other oxidation inside my block when I take off my heads. I plan on having my own heads ported, so I'll need to leave my engine in my car with the heads off for about 4 weeks before I can put them back on. Other than cover the engine with a plastic tarp, is there anything special I should do to the cylinders or where the lifters go or anything?
Old Mar 6, 2003 | 01:09 PM
Default Re: Pulling heads, then leaving them off for a month
So coat the surface of the block, the piston faces, and insides of the cylinders with WD40? Should I spray it down the holes where the lifters go or should I just stuff clean rags down in there?
Anything else, other than cover the whole thing with a tarp? TIA
Old Mar 6, 2003 | 02:27 PM
59apache's Avatar
definaltly cover the whole thing up after you put some wd40 on it
Old Mar 7, 2003 | 12:31 AM
Nasty N8's Avatar
Remove all coolant than spray them down with WD40.
Nate
Old Mar 7, 2003 | 12:43 AM
Z00's Avatar
Z00
I did the same thing. Just make sure you get all the coolant out first and spray it down. I sprayed it down when I was putting heads back on as well.
