Cam install TV2
Old Oct 19, 2012 | 01:43 PM
bwolfZ28's Avatar
I went to Fastenal and got a bolt the same size as the crank bolt just at least a 1/2" longer and did it that way. You can get one more than 1/2'' longer but you might need to take it out part way and put some washers on the pulley to prevent the bolt from bottoming out.
Old Oct 19, 2012 | 08:25 PM
bp m1009's Avatar
does anyone know where i can get a good valve spring compressor locally? i dont have time to order one. or does anyone in NJ have one i could borrow this weekend? need help ASAP
Old Oct 19, 2012 | 08:36 PM
IllusionalTA's Avatar
Abort!!!! It's 9:30 on Friday night!!! Try again next week
Old Oct 19, 2012 | 09:58 PM
bp m1009's Avatar
got 1 spring on lol only took like 2 hours
Old Oct 21, 2012 | 04:52 PM
bp m1009's Avatar
update: so i couldnt finish this weekend due to my cheap valve spring compressor. ordered the trick flow one from summit so i should be dont next weekend. finished everything else, got the cam in, ls2 timing chain, and new balancer.
Old Oct 22, 2012 | 10:27 AM
04goat350's Avatar
make sure you align the timing cover correctly
Old Oct 22, 2012 | 02:08 PM
bp m1009's Avatar
yep, pretty sure i got it aligned properly. left all the bolts loose then put the balancer on, then tightened the timing cover.
