Critique my long block build
Old Mar 12, 2013 | 07:35 PM
jdoyle's Avatar
bump for more piston and ring ideas.
Old Mar 13, 2013 | 11:09 AM
jdoyle's Avatar
Are hell fire rings an aggressive enough ring to accelerate the wear of a cylinder bore on a car that is primarily street driven?
Old Mar 14, 2013 | 05:56 PM
jdoyle's Avatar
Old Mar 14, 2013 | 07:03 PM
leeluther252's Avatar
Get the wiseco's and be done with it. Really no reason to go with anything else, unless you wanna be different and just end up with an inferior setup.
Old Mar 15, 2013 | 09:21 AM
jdoyle's Avatar
i am waiting on Erik @ HKE to call me to complete my wiseco order. it comes with the 3905GFX ring set.
how similar is the Wiseco 3905GFX ring set with a hell fire ring set?
Old Mar 18, 2013 | 10:29 AM
jdoyle's Avatar
Old Mar 20, 2013 | 09:18 AM
jdoyle's Avatar
are there any other head gaskets that are worth looking at besides GM 12589226 and cometic H1294045S?
LS6 block, LS6 heads and a 3.903 piston.
thanks
Old Mar 21, 2013 | 09:54 AM
jdoyle's Avatar
thanks
Old Mar 22, 2013 | 10:09 AM
jdoyle's Avatar
thanks
Old Mar 25, 2013 | 10:17 AM
jdoyle's Avatar
thanks
Old Mar 26, 2013 | 08:44 AM
jdoyle's Avatar
thanks
Old Mar 26, 2013 | 09:21 AM
  #32
FastKat's Avatar
Originally Posted by jdoyle
someone on another forum is saying that the forged rods are overkill and OEM rods should be used. i have been having a hard time deciding this myself and finally decided that i would run the forged rods to give me "room to grow."
what would you guys say to, "forged rods are overkill, run OEM rods?"
OEM rods would probably be okay, but an inexpensive set of forged rods might be worth it. From you OP, it seems like you have a focus on a robust valvetrain, which in my mind, would stand up to higher-than-normal RPM use. Forged rods will be a good supporting mod for this, as the rods experience exponentially more stress as RPMs increase. If you were buying new rods (either forged or stock) I'd say go with forged ones. If you already have stock rods and want to reuse them, they'd probably work, but at least get the good rod bolts.
I think those are the same ones that I used - stock LS1/LS6 MLS gaskets. Anyway, I'm very happy with mine and would buy them again.
Old Mar 26, 2013 | 09:31 AM
  #33
jdoyle's Avatar
First, thank you for your reply.
They were worth it in my opinion. I purchased a set of Eagle H Beams with ARP 2000 rod bolts.
I ran some stock MLS before and was happy with them too. Sounds to me like there arent really any new options out there for us NA guys.
Thanks again
Old Mar 26, 2013 | 09:14 PM
  #34
Thanks again
You don't need any other options. The GM gaskets are extremely good and there is no need for you to get anything else. Cometic makes some really nice gaskets but for your application there is no need to get them.
Old Mar 27, 2013 | 08:56 AM
  #35
jdoyle's Avatar
thanks for the reply.
thanks
