Can I swap pistons
Old Oct 22, 2012 | 10:34 AM
Mustang Hat'r 2's Avatar
Default Can I swap pistons
I have a 408 with 32cc dish pistons in it, i'm an Nitrous guy. Can I put new pistons in it and rering it and call it a day? I assume the crank is balenced on its own, the rods match in weight just like the piston. Is that correct or do they ballence the hole rotating assemble together?
Old Oct 22, 2012 | 11:42 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Short answer: No. You will at a minimum want/need to re-balance it when you swap to a flat-top or less dished pistons. If you go with the same brand and same bore size pistons, you can likely use those new rings though.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 22, 2012 | 01:07 PM
The motor has about 4k on it. Can I stip it down and give the crank, rods, new pistons to a shop and have them balence it and just reassemble? All I should have to do is file fit the rings, all the bearing gaps etc should be ok from the previous build?
