Thicker oil even with high oil pressure?
My oil pressure is pretty good, 50-55 at warm idle, 60 at cruise, 80 at redline. I am using M1 10W-30. My valvetrain is pretty noisy with the new mild cam, dual springs, and proper length pushrods. Would it be a bad idea to switch to a 5W-40 to help quiet down the valvetrain? This would probably increase my oil pressure even more and was worried about excessive oil pressure. The motor has about 105k miles on it, stock bottom end. I will also be going to an oil-cooled turbo in a few weeks and figure a thicker oil may be desirable.
Thanks!
Thanks!
know bout that dreaded value train noise, dont know but my noise was getting increasingly worse was going to remeasure my push rods , but put a smoke machine up exhust and found a small exhust leak where the header and the head meet,put a set of $14 gaskets on it and the noise went away, i was for sure that it was valve train noise and so did everyone else . Just $14 man give it a try, Is that factory oil psi mine is that high also, was think it was to high 57 idle 90 wot, i know my ls1 oil pump was swap out thought they might have shimed out the pressure regulator spring and im running 10/30 valvoine full synthentic thinking of droping to 5/30 mobil 1, such i not ????????
I've spent at least 20 mins feeling around for exhaust leaks and found nada. The heads are new, exhaust manifold flanges were sanded smooth, new GM gaskets, retorqued the bolts yesterday to 18 ft-lbs. I wish I had a smoke machine, that would be sweet. I got thicker oil to try, gonna change it tomorrow.
Thanks!
Thanks!
Keep in mind that there is less oil volume going into the engine at a regulated 80 psi when the oil is thicker vs. when thinner.
