great street racing cam
im looking for a great cam for mostly street racing but drag strip to low 11
right now i got all boltons -fast 90/90/ pully/ lt/ lid etc.
built trans with yank ss3600 with 3.73 gears
once i save up enough money i want to get afr 205 heads
ive looked at the eps 234 246 and g5x3 and a couple others but im openminded to others that would be better including heads
thank you
pretty healthy and most likely cause would be takers to shrivel up. AFR heads
are definitely top notch but a real stealth setup would be to send your heads
to Advanced Inductions for a CNC port job.They can spec a matching cam that can be tuned to sound smooth with the right increase in compression
ratio.
You can pop your hood to show the factory head casting numbers and if
someone asks if it's cammed....brag that you put in a LS6 cam; then show
them the taillights of your 430 rwhp combo......
Check this link out...http://www.advancedinduction.com/LSX...adsCamKits.php
ratio.
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
