Really Stupid Question - Which oil (brand and weight) should I be running?
That's MISTER MODERATOR
DO NOT use that Lucas oil stabilizer. It's just 90 weight oil with soap and will foam up with air. Discussed here a few times. There's a video somewhere.
Filters:
Wix (same as CarQuest), Mobil One Extended, K&N, Amsoil, Bosch Long Distance, Baldwin. Stay away from STP, Penzoil or any odd names like the store's name. NO FRAM ANYTHING.
OIL: Any good name synthetic oil should do, many use Mobil One with good results.
Royal Purple filters and oils are pretty good, nothing much better than the other stuff but way expensive, so I didn't list it.
I use German Castrol 0W-30 and a Fleetguard Microglass filter.
The truck filters are a bit longer and stick down more on a F-Body so if you have a Firebird or Camaro and it's dropped, forget it.
A magnetic oil drain plug is a nice touch.
Filters:
#36
Hey Jake, while I love the good folks at WS6, they get ten bucks a quart. There are AutoZone stores around your area and, at least here in NY, they're running a sale on the stuff with a toss-away Fram filter. Even not on sale, it's less than WS6 plus there's no shipping.
#37
Shell Rotella T 15-40 in mine.
Brad Penn is some of the best oil on the market. It has all the additives in it that has been taken out of your off the shelf oils. Brad Penn may be hard to get. I have a case sitting in the garage right now. The only thing with it though is it may make your 02 sensors go south a little sooner.
