Timing chain & oil pump ?
Old Oct 25, 2012 | 07:46 PM
jaywill's Avatar
Default Timing chain & oil pump ?
What should i get 3 my 5.3 build ?
Old Oct 25, 2012 | 07:53 PM
wildcamaro's Avatar
Ls2 chain and ls6 oil pump or a melling m295...cheap and reliable
Old Oct 25, 2012 | 08:27 PM
jaywill's Avatar
Thanks a lot !
Old Oct 25, 2012 | 08:34 PM
supersick99z's Avatar
I have a stock ls1 oil pump for sale Oh and look you're only down the highway from me...I'm in Greensboro
Old Oct 25, 2012 | 08:47 PM
chadroosa's Avatar
i would do a 10295 over a m295...
Old Oct 25, 2012 | 08:57 PM
litle88's Avatar
I agree, better pumps!
But what are your plans for the 5.3.
Old Oct 25, 2012 | 09:11 PM
jaywill's Avatar
A little street and strip action... 60/40
Old Oct 26, 2012 | 03:31 AM
jaywill's Avatar
who r they made by ?
Old Oct 26, 2012 | 04:24 AM
dr_whigham's Avatar
The Scammer Hammer
Veteran: Marine Corps
Ported LS6 oil pump and an LS2 Timing set from Yank.... Comes with new gears as well. Don't forget the oil pump o-ring.
Timing Set https://ls1tech.com/forums/parts-cla...new-gm-50.html
LS6 Oil Pump
http://www.texas-speed.com/p-107-tex...-oil-pump.aspx
Old Oct 26, 2012 | 12:42 PM
litle88's Avatar
Melling oil pump and C5r timing chain by katech. Don't forget a good crank pulley as well.
Old Oct 26, 2012 | 05:14 PM
salemetro's Avatar
^^^ THIS!!
LS2 timing sets are too sloppy for my liking....I learned this after running one for 3k with the damper. I'll never use another one. Yeah the kit I use (C5R w/ hex-a-just from Cloyes) is pretty spendy, but it does the trick. I've never used any other pump than Katech, so can't really comment there.
Old Oct 26, 2012 | 06:51 PM
dr_whigham's Avatar
The Scammer Hammer
The LS2 chain is ridiculously hit and miss. Mine was tight as hell, but I also spent the extra 15 or 20 bucks @ Yank and opted for the new billet timing gears. Maybe that helped?
I seriously wonder how much timing chain slack can be attributed to utilizing stock cam and crank gears. I'm not disputing ANYONE'S claim, as I've seen it posted here too many times to count. Just curious.
Old Oct 26, 2012 | 07:58 PM
chadroosa's Avatar
i used rollmaster double roller timing set...its pretty tight
Old Oct 30, 2012 | 07:57 PM
jaywill's Avatar
how about this oil pump ...
http://www.summitracing.com/parts/mel-10296
Old Oct 30, 2012 | 08:03 PM
kwiksilverz28's Avatar
LS2 chain and Melling 296 pump
Old Oct 30, 2012 | 08:32 PM
badazz81z28's Avatar
I would think minor slop would tighten up when the engine warmed up from thermal expansion.
Old Oct 31, 2012 | 12:26 AM
JakeFusion's Avatar
Super Hulk Smash
Katech/IWIS C5-R Chain and Melling HV 10296 as previously said. Just use the lighter spring in the HV Melling pump and run 6 quarts and you'll be good to go.
