ARP or oem replacement main studs???
Old Oct 30, 2012 | 07:35 PM
jaywill's Avatar
Default ARP or oem replacement main studs???
do Arp's fit without machining ? Or should i use stock replacements ???
Old Oct 30, 2012 | 09:05 PM
conan's Avatar
What are you building this motor for ? N/A, boost ?
You should have the main caps checked when using studs and line honed if needed.
Old Oct 31, 2012 | 12:13 AM
bww3588's Avatar
Agreed. A line hone is usually needed with the studs. The stock bolts will hold over 500 wheel, and personally I have never seen a main bolt failure.
Old Oct 31, 2012 | 03:30 AM
jaywill's Avatar
thanks !
Old Oct 31, 2012 | 08:46 AM
HPbyGD's Avatar
Do the aluminum and iron block use the same bolts ? I need a set of stock bolts for an aluminum block if anyone has a set laying around would you pm me and let me know?
Thanks Gary
Old Oct 31, 2012 | 09:28 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Thanks Gary
We show the same part number for these, but if you are unable to find a set, we can get you some. Feel free to give us call even if you have any questions.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Oct 31, 2012 | 10:04 AM
bww3588's Avatar
Thanks Gary
Same bolts, same caps.
Old Oct 31, 2012 | 02:15 PM
Coonass350's Avatar
I am currently rebuilding my LS1 & am wanting to go back with GM replacement main & side saddle bolts. But for some reason cannot find any anywhere. I do not want to use ARP due to the honing need.
Old Oct 31, 2012 | 03:09 PM
badazz81z28's Avatar
You have ARP now and want to go back to OEM? Why?
Old Oct 31, 2012 | 05:52 PM
jaywill's Avatar
I would like to know where you can get the Gm 2 ?
Old Oct 31, 2012 | 05:55 PM
Sales2@Texas-speed's Avatar
We can get the OE GM bolts, but do not regularly stock them. If I recall correctly, they are about $110 or so for the full set (30 bolts/studs total).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Oct 31, 2012 | 09:50 PM
bww3588's Avatar
Check rock auto, or GMpartsdirect
Old Oct 31, 2012 | 10:32 PM
Even though we dont stock them, we can get them from our local distributor pretty quick (within a day or worst case two).
__________________
