Which cam would you pick from these two?
or
231/238 .617"/.585" 113+3
My mods are 2002 Trans Am, M6
241 heads- will upgrade to AI 243's in the future
3:42 rear, stock 10 bolt-will also upgrade in future,
Fast 90/90-blackwing lid,85mm MAF
ARH 1 7/8 longtubes with catted y-pipe.
I had two cams spec'd and undecided which to go with. Any suggestions?
Since you have the manual transmission... the additional duration ( actually its the earlier exhaust valve open point) will help the motor make more torque above peak but takes away some below... this is great for a manual car because the rpm fallback on the shifts is way less versus an automatic car. You are already above the rpms where the additional evo reduces torque and it will pull like crazy throught the midrage and into the upper range...
Add a 3.73 to your rear end upgrade and it only improves this situation.
If you go bigger, it will be a bucking beauty. Or like the other post says, 3.73's or even 4.11 gears.
P.S. when you put gears in your car, don't go with anything longer than a 3.90 gear. I have 4.10s and still bog a bit coming out of the hole launching at 3500RPM with slipping the clutch a bit. I still get ~125 out of 4th so that is enough for me. Anything after that you are just looking for trouble.
Hopefully the link is good. This is threw long tubes. Tsp y pipe and magnaflow car back. Stock heads. Geoff at eps tuned this car. It loped harder but he threw some extra timing on it to mellow it out.
