how do you guys do it!!!!
Old Apr 11, 2004 | 09:41 PM
shaneSS's Avatar
Default how do you guys do it!!!!
I am dying to put a huge cam in my car. ie the TRex or something a bit smaller. The only problem is emissions! i live in Virginia and we have smog tests every 2 years. i dont know what the laws are in every state but I just wanted to know what some of you guys are doing to get past emissions with your big cams.
I just dont think its worth the $$$ and the work to put in a cam unless its going to put me in the 400 rwhp range. Tho other solution is a SC but thats over 5k!!!!
i just need more POWER!!!!!!!!
Old Apr 11, 2004 | 09:46 PM
jmX's Avatar
jmX
If you only have a test ever 2 years, just put the stock cam in for a week, every 2 years. Problem solved. A cam only swap can be done in under 2 hours, if you arent touching the springs (which you wouldnt be when going back to stock).
Old Apr 11, 2004 | 10:02 PM
jerflash's Avatar
hey did you ever try putting a 20 in the testers hand?
works for me and my 89
Old Apr 11, 2004 | 10:16 PM
pdd's Avatar
pdd
would the car run shitty by putting a small cam back in the car without a tune?
Old Apr 11, 2004 | 10:19 PM
foff667's Avatar
LS1TECH Sponsor
im not sure what im gonna do after my 23 months are up...i'll probably swap the stock cam back in and hope they dont do a visual since its just a plug in right now
Old Apr 11, 2004 | 10:24 PM
jerflash's Avatar
y would you do that??????????
just put some money in the guys hand
solves alot of problems
Old Apr 11, 2004 | 10:28 PM
foff667's Avatar
LS1TECH Sponsor
when your car is as loud as mine is i dont think just a $20 would do
Old Apr 11, 2004 | 10:31 PM
shaneSS's Avatar
Yeah I have obviously though of slipping the dude a $20 but I just didnt want to depend on it. The cam swap back to stock was also a though untill I remembered that IM LAZY! I think I may just start saving for the ATI D1SC!!!!!!!!!!!!!! oh and I guess a new rear........
Old Apr 11, 2004 | 10:33 PM
shaneSS's Avatar
Wait a minute...............a Wet kit is looking pretty attrative right now as well.
Damn car!
Old Apr 11, 2004 | 11:18 PM
brandon1221's Avatar
Just save up more money and get a 387 stroker kit. You can get one for around $4,000+install. That is expensive but i believe will pass emissions still and its just more impressive to run good times all engine.
Old Apr 11, 2004 | 11:30 PM
01_SuperSlow's Avatar
That's what I would do
Old Apr 12, 2004 | 08:01 PM
lazerlemonta's Avatar
Not that it matters, but you could garage the care in a county that doesn't require emissions.
