Wanting mor power
WHAT IM ASKING IS WOULD IF I'LD BE BETTTER TO DO THAT OR JUST HAVE MY STOCK LS1 HEADS CNC Ported ,
WHAT BOUT MILLING THEM DOWN TO UP COMPRESSION AND WOULD I HAVE TO FLY CUT MY PISTONS , NOT SURE IF THE FLY CUTING WILL ADD RISK TO BURNING THROUGH A PISTON SENCE IM RUNNING A 150 SHOT
1500 DOLLARS FOR PRC Stage 2.5 5.3L CNC Ported Heads SEEMS ALOT FOR 22 HP AND SEE SMALLER FLOW
NEED ADVICE
With that said I have those same heads, and i'm sure all things being equal, that I gained more than 22 hp lol. The car runs strong as hell with these heads and Torquer V2 cam correct me if im wrong this is why everyone is bolting on the heads for mor compression
And if I'm going to drop 1500 on heads, I'll save a bit more for an aftermarket casting. Hell, there's AFR's and TFS's in here for that price... sometimes a bit lower. But agreed with HCI2000SS... They should have picked up more than 22hp PEAK, and a lot more under the curve, where you're car **likely** spends the majority of it's time anyway.
