4.000 crank with 6.100 rods
i have a 6.0 with stock crank 6.100 h beam rods and wisco pistons to match the rod. is it possible to take the 3.622 crank out and put a 4.000 crank and use the same rods and piston?
Rule of thumb here...whenever you change the stroke and leave everything else the same (sleeve length/width, deck height) you will need to change both the rods and the pistons. In order for the piston to not jump out of the cylinder with the longer stroke something else has to give, in this case different length rods and different sized pistons.
Depends on piston brands, we used to do that to reduce weight as well. In hotroddin' one thinks out of the box. Compression used is a factor as well, no boost or nitrous.
While it is not common practice it is doable.
Moderator
I understand thinking outside of the box, but that seems like its asking for trouble. Most ring lands are less than .300" thick, so trimming half of that off would drastically reduce the strength of the ring land, not to mention increase the heat the top ring is subjected to. Without knowing how much power the engine is meant to make, that suggestion should at least come with a disclaimer.
Kaase did something interesting in a very similar combination by using a very thick head gasket (like .250") and then put spacers under the manifold to effectively lengthen the runners.
But then again, if the correct pistons aren't in the budget then custom gaskets probably aren't either.
LS1Tech Premium Sponsor
A piston .100 OUT of the hole and a gasket .052" thick puts your piston .048" ABOVE the gasket...that's not the same as .048" quench. .048" quench would be a .052" gasket and the piston just .004" out of the hole.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
That is some good **** though
I literally thought to myself "What has he been smoking today?"
__________________
