what heads ?? new 370 build
The question here...what is the budget? If the cash is there, go the best possible...AFR
If I were you, I would sell the cam and the intake.
Pick up some CNC ported LS3/L99 heads from Summit/LS3 intake/proper spec'd cam.
You will be much happier.
Because it's the right way?
If you're on a budget look at TEA, AI or PRC for ported stock casting heads.
If you have a little more room to work with money wise, you can't beat AFR or TEA CNC TFS 225 heads.
Here is a link to the heads: http://www.texas-speed.com/p-3515-pr...ral-heads.aspx
