Going back and forth with my build choice. Need help
Old Nov 6, 2012 | 02:20 AM
transamfreak01's Avatar
Default Going back and forth with my build choice. Need help
I was planning on building a ls2 but money has been a little bit of an issue as I am in the process of a move. I already have a ls1 block with AFR 225 (1660) heads 63cc. These heads have upgraded Ferrea valves and Manley dual springs and titanium retainers, 102 intake/tb, 100 mm maf and my question is would this be over kill for a ls1? Not sure on ci yet but would like some input on that. I still need to decide on a cam and this motor either way will be forged. I appreciate any input
Old Nov 6, 2012 | 02:23 AM
I'm not worried about hp numbers but I would like to build a nasty street car with potential of going low 11s high 10s on motor. I also have a plate kit going on the car but its going to be a little girl shot of 100-150 and no more
Old Nov 6, 2012 | 04:33 AM
A.R. Shale Targa's Avatar
the 225 runner would still work fine however AFR intends for them to be used on slightly larger cube engines. If you cant afford a 4" stroker kit then the key
to making it work @ 346 or 347 will be to mill them and use thinner .040
Cometic gaskets to get 11 plus to 1 compression and stay a bit conservative
with the camshaft to build good cylinder pressure (torque)...228-232 range
Old Nov 6, 2012 | 05:33 AM
low2001gmc's Avatar
MASS seller approved
a stroked ls1 would be best with them heads and more cubes than ls2....some to consider....good luck with project....rob
