Groove on top of piston?
My question is, what is the groove? Is it going to be a problem? Is it caused by something that could damage the engine?
While I am rebuilding the bottom end, I am installing an MS3 cam, ported LS6 heads, LS6 intake, & American Racing LTs.
Well, onto the pic. Let me know something guys, Thanks in advance.
Brenton
Will it be okay to use the pistons since ill be going with new heads, valves, etc? or am I pretty much fucked?
When I go back in with the MS3 cam I will be going with some PRC .650" valve springs so that should be sufficient. Ill be using stock rockers with the Comp Cam Trunion Upgrade, in case any of this matters.
Ill go ahead and finish cleaning the others and get ready to install them. Thanks guys.
Yes this is the original block it came out of. I havent checked the cylinder yet for any roughed up spots but will in just a few minutes.
I mean when I slide the piston in, it didnt seem to be rough feeling. The mark on the piston is faint and can barely tell that its there with your fingernail & the same with the little mark on the cylinder.
Before my friend wrecked the car he didnt have trouble with the engine, it ran strong.
