LS1 Engine Pre-lube (Priming)
I made a pre-luber with the correct fittings....However, I just noticed the oil port in the Kent Moore instructions is blocked by the alternator (F-body set-up). Would I get the same results if I pumped oil in the back through the oil pressure sensor port?
