LQ4 bored .060 over for boost?
Old Nov 11, 2012 | 08:30 AM
dmaxvaz's Avatar
Default LQ4 bored .060 over for boost?
Anybody know if a lq4 bored 0.060 or 0.070 over would be okay for boost?
Old Nov 11, 2012 | 08:57 AM
96capricemgr's Avatar
why do you want to bore so far?
If to salvage a block I would just get another.
If chasing displacement then...................................
Old Nov 11, 2012 | 09:17 AM
Tainted's Avatar
First you need to have that block sonic checked to bore it that much safely.
Two, you need to measure wall thickness
Third, how much power and boost are you looking to make?
This could be a recipe for disaster
Old Nov 11, 2012 | 09:20 AM
batboy's Avatar
N/A, yes... FI, no...
Old Nov 11, 2012 | 09:32 AM
Gunslinger09's Avatar
You need to read this. I would leave the block as is for forced induction of any kind or sleave it if it need to be larger bore for Ls3 type heads.
Old Nov 11, 2012 | 10:00 AM
dmaxvaz's Avatar
I bought a stroker 408 and the block is at 4.031 and need new pistons. Wiseco has some in a 4.035 size, but need to be special ordered at 2-3 wks lead time. So I was weighing other options availiable. I just might use my ls2 block with a 4.005 piston. This engine will be turbocharged and goal is 800-900 HP in a tbss
Old Nov 11, 2012 | 02:21 PM
I wouldn't waste an aluminum block on a TBSS, just find another iron LQ4/9 block that you can get away with a standard minimal overbore on.
Old Nov 11, 2012 | 02:23 PM
Tainted's Avatar
for you to really hold 800-900hp, you need a better block or a sleeved one. that bored out 6.0 may hold for a while, but its not the route id take.
