One valve sits lower than the rest?
Old Nov 14, 2012 | 12:28 AM
Ferocity02's Avatar
Default One valve sits lower than the rest?
Pulled my valve cover today to investigate a tapping noise that started after a cam/head swap a few weeks ago. I noticed that the exhaust valve on cylinder 7 sits a little lower than the others. As in, the tip of the valve stem doesn't protrude as far out of the head as the other valves. This means that the preload on this lifter is slightly less than the others, about 0.020-0.030" less, and might be the source of my tapping. The valve stem doesn't have any abnormal play in it. Looks normal otherwise.
They are stock 799 heads I got new, now have about 500 miles on them, milled 0.022. Cam is a 212/212 0.561/0.561 114LSA. Brian Tooley dual springs, installed correctly, not broken. LS7 lifters with about 30k miles on them, they were in the engine before the swap. I am using 7.325" pushrods which I measured to give me about 0.075" preload. Oil pressure has been fine, 45psi at idle, close to 60psi at cruise at 1700 rpm.
I also ran it without the valve cover to see how much oil was getting to the rockers, video here: https://ls1tech.com/forums/generatio...eo-inside.html
Anyone had a similar issue?
Thanks!
Old Nov 14, 2012 | 02:12 AM
bww3588's Avatar
Makes sense. I would back all your rockers off and look carefully at the valve stems then. You may have an exhaust seat working it's way out. If that's the case, you need to get it apart ASAP.
Old Nov 14, 2012 | 03:24 AM
vettenuts's Avatar
Bent valve would do this. If this wasn't there immediately after the parts swap, any over revs or missed shifts (I assume a stick) that might have let the valve tag the piston? Do you know the PTV?
Old Nov 14, 2012 | 09:39 AM
Ferocity02's Avatar
That's why I'm thinking, but my rev limiter is stock, 6000rpm I think for a truck, and I've only been there a handful of times. Never missed a shift either. The pushrod wasn't bent. Didn't check PTV because my cam is such low lift, even with the milled heads.
Old Nov 14, 2012 | 09:49 AM
J Glen's Avatar
I agree that the cam is awful small to worry about PTV, but you should still check it out. Oh and lift doesn't have anything to do with PTV clearance. Duration does.
Old Nov 14, 2012 | 11:28 AM
Ferocity02's Avatar
Lift has a LOT to do with it. Duration is only 212/212.
Old Nov 14, 2012 | 11:48 AM
96capricemgr's Avatar
The reason he said lift is not that critical point is because the cam is nowhere near peak lift when the piston is near TDC. Think about it.
Old Nov 14, 2012 | 11:57 AM
bww3588's Avatar
No, it doesn't....see above.
Old Nov 14, 2012 | 12:11 PM
Ferocity02's Avatar
Learn something new everyday!
Anyway to see if the valve is bent without pulling the head? Maybe pulling the spring and spinning the valve to see if it feels strange is the best I can do.
Old Nov 14, 2012 | 12:16 PM
boroscope, leakdown or compression
Old Nov 14, 2012 | 12:33 PM
Ferocity02's Avatar
I did a compression test and cylinder 7 was about 170psi while the rest were 180-185psi. Is this indicative of a problem?
