1.75 pro mag rocker arms
Are there any clearance issues with the comp pro mags? I heard 98 valve covers need some grinding? Please let me know what needs to be done inorder to fit. Thanks in advance
PS. Setting preload with shims is just a big PITA. Hence Pro Mags are on the way....
you have to cut the baffle out on the passenger side that the pcv used and pull the "plate" insert out of the driver side one.
not sure if 98's are any different than a 2001 or not on the inside.
