Can I run the engine without rockers?
Can I pull both rockers off a cylinder so their lifters aren't being used? If the tapping goes away with the rockers off then I can assume the tapping if from one of those two lifters. If I were to do this, I would only let it idle for 10-15 seconds, enough time to hear if the tapping is there or gone. However, 10-15 seconds would be roughly 100-160 revolutions, ouch.
Here is what I would do... Remove both rockers and pushrods and make sure the lifters stay up in the lifter guide, unplug injector, unplug spark plug. Would I need remove the spark plug? I'm hesitant to because it would make a TON of noise and probably cover the sound of the tapping.
So am I crazy, or is this a reasonable idea?
My biggest concern is potential damage to the cylinder walls and perhaps other damage caused by doing many compressions in a row without fuel or combustion.
What I just suggested may be a safer way to check and pretty easy
Kurt
This is ok to do... air will simply be pulled into that cylinder via intake port, it will be compressed, and then expelled via exhaust port; leave spark plug in otherwise there will be too much noise.
This is how a running compression test is done (pressure gauge screwed into spark plug hole, measuring pressure in one cylinder while engine is running), does not cause any damage.
I would prefer to know what the problem is before pulling the head. This is my daily driver so pulling the head is a big deal. And at the rate I work, it would take me a full day, maybe two
Kurt
