Removing the timing chain gear ???????
Old Apr 12, 2004 | 08:33 PM
1Fst98ta's Avatar
Default Removing the timing chain gear ???????
How the hell do you get that bottom get off of the crank ... i tried for about a hour or so and couldnt get it to move ... I was using a claw hammer and screw driver but didnt do ****
Old Apr 12, 2004 | 08:40 PM
Ferocity02's Avatar
I think I use the pulley puller, the same one I use to get off the crank pulley.
Old Apr 12, 2004 | 09:14 PM
JoeyGC5's Avatar
Three jaw puller should work fine, just take it easy. Please don't ever use a prying device and hammer on a cranckshaft!
Old Apr 12, 2004 | 09:38 PM
1Fst98ta's Avatar
Good deal , i will have to go rent one
Old Apr 12, 2004 | 09:41 PM
Ferocity02's Avatar
How did you get the crank pulley off without a puller?
Old Apr 12, 2004 | 09:47 PM
1Fst98ta's Avatar
You cant use a pulley puller you use on a asp pulley that uses bolts , now can you ?
Old Apr 12, 2004 | 09:53 PM
1Fst98ta's Avatar
I only did the screwdriver deal because i coulda swarn i saw someone post that on here ... Well it didnt work anyways , i d0nt think i messed anything up ... but i can see what you mean about that not being a good idea
Old Apr 13, 2004 | 07:32 AM
JoeyGC5's Avatar
Just remember "Haste makes waste"
Old Apr 13, 2004 | 02:51 PM
robertbartsch's Avatar
Use a puller; Suggestion: read the instructions from the JXM web page. They are very detailed and easy to follow.
Old Apr 13, 2004 | 03:17 PM
Will V's Avatar
I used a hybrid of a 6inch gear puller with 4 inch gear puller arms attached on my main pully and then used a 2 jaw puller for the lower timing gear.
When you reinstall your new lower gear try heating it up to make it go on the crank snout a little easier. I did this and then butted up the old gear to the new one and tightened my old bolt down to seat the new gear. No problems at all.
Old Apr 13, 2004 | 05:16 PM
eallanboggs's Avatar
Since you already have the crank pulley off(I guess?) you need to take care to find something solid for the puller screw to buck up against. I used a LARGE allen head cap screw on a couple of BIG flat washers. The flat washers need to be just slightly smaller than the OD of the crankshaft. The allen head cap screw forces the puller screw to be concentric with the crankshaft so the sprocket comes straight off when you torque down the puller screw.
