Ls1 heads set up help!!
Old Nov 19, 2012 | 04:18 PM
98 ls1 jimbo's Avatar
Default Ls1 heads set up help!!
I have about $3500 to spend on my ls1. I need help what should I get Texas speed heads cam set up I need to know what set up I want the most power for my cash. I want a aggressive cam but not to big. What fuel injectors will I need and do I need to change fuel pump as well? Should I just port my stock heads and do a cam? And I have one more question would It be save to do a rear mount turbo with a aggressive cam and head set up? Only about 5 psi tho? What power do u guys think ill make with just heads cams headers intake ext.?
Old Nov 26, 2012 | 02:50 AM
AceBoogie's Avatar
TSP cnc heads
MS3 cam
full bolt ons and tune
should put you close to the 430whp range
Old Nov 26, 2012 | 09:31 AM
Sales3@Texas-Speed's Avatar
LS1Tech Premium Sponsor
Give us a call if you have any questions about our products, we will be happy to help you figure out what you need and what will work with future setup.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old Nov 26, 2012 | 09:49 AM
BKsNHRA's Avatar
If i had the money i would either send mine out to AI and have the ported or just grab a new set of TSP 2.5 5.3 heads and i would lean on the cam a little harder. I like my 226-230 but wouldent mind haveing a little more.
