Comp Pro Magnum 1.75 rockers
Just a small issue that I ran into today. Yes they fit under the stock valve covers. BUT you have to pull the sheet metal PCV isolater out of the left tappet cover and grind down a web there too. Now if I was still using the LS1 PCV system this would greatly improve my chances of ingesting more oil. But I just changed over to the LS6 type of PCV so it's not an issue for me.
Just wanted to pass the info on.
mine werent even close to fitting. had to grind down two coil pack bosses on one side and remove the isolater on the other. I switched over to the LS6 PCV too.
ls6 pcv system is different..new valley pan. Supposed to be better.
I think you can see the install at ls1howto.com. Its about $70 if I remember correctly.
Snug the pushrods up and then about 1/5 turn more (.008-.010").
Thanks for the info
When you mention the bosses I am assuming you mean the ones on the Passengers side valve cover and the isolator being the alum plate on the drivers side rear cover. Is this correct. Thanks again...
