ebay cylinger head install kit (any good?)
Old Dec 10, 2012 | 05:05 PM
Neenjah's Avatar
Default ebay cylinger head install kit (any good?)
http://pages.ebay.com/motors/link/?n...d=370709367253
Just curious if this is any good mainly in the head gasket and head bolt department.
Is there a better way to buy these parts?
Just trying to fix a very minor head gasket leak.
Old Dec 10, 2012 | 05:15 PM
3rdCoastPowerSports's Avatar
If im not using ARP bolts and Cometic gaskets then i will only use felpro or victor reinz gaskets and bolts. try contacting a local automotive machine shop and ask them for a kit. I would not purchase head gaskets and bolts on ebay. way way way to much counterfeit **** on ebay these days. just my 2 cents though
Old Dec 10, 2012 | 05:30 PM
Neenjah's Avatar
Thank for the advice man.
If been reading to use only gm gaskets and that's marketed as "gm performance parts"
Old Dec 10, 2012 | 05:35 PM
jrr344's Avatar
I don't think you would have a problem ordering through summit racing, I have bought alot through them and havn't had any problems, but I can't comment on the parts themselves.
Old Dec 10, 2012 | 06:13 PM
keith102371's Avatar
http://www.summitracing.com/parts/na...7/media/images
Old Dec 10, 2012 | 06:54 PM
muayyadf1's Avatar
These are GM parts. I don't see any reason not to buy them. Recently GM lowered the prices of these parts, that is why you find them cheap.
Old Dec 10, 2012 | 07:09 PM
97camaro383's Avatar
I'd just give summit a call but looks like a good deal to me.
Old Dec 10, 2012 | 09:11 PM
snyousef's Avatar
Same kit is on JEGS for $109!
http://www.jegs.com/i/GM-Performance...99217/10002/-1
Nothing wrong with it as it's made by GM...
Old Dec 10, 2012 | 09:15 PM
garygnu's Avatar
check Texas Speeds price for a head swap kit.
Old Dec 10, 2012 | 09:29 PM
muayyadf1's Avatar
If you have an ls6 block or later, these bolts won't work. You need all short bolts for yhe longer ones.
Old Dec 10, 2012 | 09:35 PM
badazz81z28's Avatar
Have Summit Price Match, they are better at shipping than JEGs is...
Old Dec 10, 2012 | 10:34 PM
snyousef's Avatar
GM parts direct actually has it for $100....only question I have is the head gasket MLS or graphite?
Old Dec 11, 2012 | 08:34 AM
onefast84's Avatar
Summit racing, and gm parts. Thumbs up!!
Old Dec 11, 2012 | 07:12 PM
David Q's Avatar
I just did a full engine rebuild minus the rings and bearings, all from rockauto.com. Great pricing and all GM or factory replacement parts.
Old Dec 11, 2012 | 08:00 PM
FAD2BLK93's Avatar
Why would u not at the very least do bearings? I would think that would be a necessity? Piece of mind at least, right?
Old Dec 11, 2012 | 08:01 PM
96capricemgr's Avatar
Just a minor correction, some are saying "made by GM" Very unlikely. Now "made FOR GM" I would go along with.
Many OEM parts are very good, have to consider target service life of a OEM engine is measured in hundreds of thousands of miles. There is often a lot of overkill built into engine components.
Old Dec 12, 2012 | 07:14 PM
David Q's Avatar
I did replace bearings and rings, I used a set of coated race bearings supplied by Erik at HKE and the rings were supplied in the wiseco piston kit. I just bought all of the gaskets and head bolts on rockauto.com. Good catch though.
