Broken bolt during valvespring install HELP!!
Old Apr 14, 2004 | 12:05 PM
BlackWS602's Avatar
Default Broken bolt during valvespring install HELP!!
During my cam install I was swapping the springs using a waterpump bolt for my compressor. The bolt just snapped in one of the holes How can I get this out?
Old Apr 14, 2004 | 12:15 PM
Scalpel's Avatar
This really should be taken out of jMx's site. The water pump bolt is too weak, IMO and as evidenced by others that have done the same, to use on that spring compressor. Spend the $25 to get Larry's tool and the stud and nut it comes with to do it right.
Now, to your question. You can:
By an EZ-out to remove the broken remains
Use a Dremel to cut a slot in it and use a flat head screwdriver to back it out
weld something to the top of the broken portion to serve as a way to back it out
Take the head off and go to a machine shop to have them remove it
Old Apr 14, 2004 | 12:16 PM
BlackWS602's Avatar
guys I should actually try moving the bolt before I bother you guys came out with my fingers.
Cannibal I used my waterpump bolt because the Patriot Gold's are alittle too tall for the rocker bolt. I'm gonna goto the dealer and buy a waterpump bolt then goto lowes and see if I can find a long grade 8 bolt to use
Old Apr 14, 2004 | 12:22 PM
KGSloan's Avatar
that's what i did. i've used a longer grade 8 bolt from lowes on 3 spring swaps now without any trouble. glad you got the broken part out
Old Apr 14, 2004 | 12:23 PM
BlackWS602's Avatar
you wouldn't happen to know what thread size the bolt is do you? I'm not sure if lowes has the thing where I can find out
Old Apr 14, 2004 | 12:27 PM
ross's Avatar
It will be a metric bolt, so you may have a hard time finding it at lowes. I've had better luck with Ace. They carry an amazing selection of bolts, grade 5 and 8.
To figure out the thread size, just try and thread different nuts of known thread sizes over it, and then when you find one that fits, take that nut and thread it over the bolt you want to buy.
Old Apr 14, 2004 | 12:31 PM
2xLS1's Avatar
Get a stud and a nut or your next post might be " I just pulled the rocker bolt threads out of my head." . M8x1.25 is the size.
Old Apr 14, 2004 | 12:33 PM
2xLS1's Avatar
12551926 is the water pump bolt.
Old Apr 14, 2004 | 02:04 PM
Scalpel's Avatar
Get a stud and do it right, trust me. 8 MM x 1.25.
Old Apr 15, 2004 | 12:19 AM
jrp's Avatar
jrp
SN95 Director
samething happened during the swap me and charlie did on saturday jon.
Old Apr 15, 2004 | 06:41 AM
Z06Ron's Avatar
This is pretty much the way I just got through doing it. After hearing of all the bolts breaking off. I went to NAPA and got some long 8mmX1.25 bolts and nuts and went to town. Even though the bolts were not grade 8's they are not likely to break if screwed in good and then use the nut to press the spring. Studs would be better but the bolts will work.
Old Apr 15, 2004 | 04:59 PM
Krab's Avatar
That's exactly what I did too. I just bought a longer bolt, a nut, bolted down the bolt in the rocker hole, and went to town. Did all sixteen without a problem.
Old Apr 15, 2004 | 05:02 PM
mike c.'s Avatar
if you have the new ls1 valve spring tool,do you still need the 8mm stud??
Old Apr 15, 2004 | 06:27 PM
Revelation222's Avatar
As JRP mentioned this happend to me last weekend. I got some advise from another member of this board.
Take a Dremel tool with a cutting wheel and cutr a straight line through the top. Then use a short fat flathead screwdriver to get it out far enough so that you can grab it with pilers then just twist it out. Worked great for me.
If it is in an area where you can fit a drill then im sure you could use a standard bolt-out kit.
If it is broken below the opening of the hole then I dont know what to tell ya. Mabe then try craftman's micro bolt extractor kit? Those might reach.
Good Luck to you.
Old Apr 15, 2004 | 11:35 PM
Krab's Avatar
Which tool is that? Is it the one that you compress the spring using a ratchet? If so, then it would probably still be best to have a stud in there, or make sure the bolt you're using is bottomed out so you apply pressure to all the threads. I personally wouldn't (and didn't) spend my $$ on that tool when you can make one yourself for about $7 or so and works better IMO.
