I need some pistons.
Old Dec 13, 2012 | 07:02 PM
longcut's Avatar
Default I need some pistons.
I bought a block from Craigslist with a spun rod bearing and had a local (reputable) machine shop turn the crank, bore it 10 over and new cam bearings. Not sure if I'm going to use the factory rods. I haven't searched any threads about it yet but, either way I need a set of 10 over pistons.
Its for a street car looking to make around 450 and bullet proof. Ill continue to do some research but any suggestions would be great. Looking for best bang for my buck.
Old Dec 13, 2012 | 07:05 PM
longcut's Avatar
its a 00' - 02' 5.7 block I believe from the 12559378 stamp.
Old Dec 14, 2012 | 07:34 AM
ckpitt55's Avatar
In for replies as well, I've got the same goals as you there longcut
edit: I know most aftermarket pistons use a floating pin - anyone have a ballpark on what it'd cost to have new pistons hung on the stock rods?
Old Dec 14, 2012 | 09:00 AM
omc8's Avatar
Thats good casting, Ive got one too , its next best thing to the 1168 LS6 casting. I too would like to find a budget piston like speed pro , but they are press pin rods and I want to go floating . I dont think Federal Mogul makes a 3.9x floating hyper piston.
Old Dec 14, 2012 | 07:59 PM
longcut's Avatar
looks like Speedpro is the piston. Have your machine shop call for a pricing.
My final bore was 3.907 and 5/10ths. I'm surprised there are not more aftermarket pistons readily available for a .010 cut.
Old Dec 15, 2012 | 09:19 AM
omc8's Avatar
If its floating pin shoot me a part #
Old Dec 15, 2012 | 11:29 AM
longcut's Avatar
Ill be back at the machine shop Monday, I got there to pick up my block right as they were closing and the books lady was the only one there.
Old Dec 28, 2012 | 10:24 AM
omc8's Avatar
2005 LS1 / LS6 were floating , so you would think Speed Pro would make a replacement for them.
