Thunder racing 224\224 112 LSA
Old Apr 14, 2004 | 04:25 PM
zyal8r's Avatar
Question Thunder racing 224\224 112 LSA
Any one used the 224\224 112 cam? If so is it a noticable power increase over the stock cam with a stock tune? Does it sound good?
Old Apr 14, 2004 | 04:30 PM
JDPZ28's Avatar
Need more info on your mods. See sig for my results. I gained about 40rwhp with just
the cam swap. And yes it sounds good!
Old Apr 14, 2004 | 04:36 PM
Brian2001SS's Avatar
Mines on a 114lsa. There is a very noticable difference as long as you use headers. I'm still am on a stock tune.
Old Apr 14, 2004 | 04:51 PM
Hardtop00SS's Avatar
The TR224 is a very popular cam in the LS1 community, I'm running the 224/224 .563 112LSA, which gave me a noticeable gain. The other good thing about the TR224, is that if you go with the .563 lift, it won't eat up valvepsrings as bad as other cams. If you have a 6spd, go with the 112 LSA, if an auto, 114 LSA. I'm running on a stock tune also, only problem is when it's cold, it wants to stall sometimes, but once it warms up, it's good to go. Good luck
Robbie
Old Apr 14, 2004 | 05:42 PM
NaSSty99's Avatar
Thumbs up
as long as you get long tube headers, it will give you a good gain, (at least in my case)
at first i put this cam (TR224 on 112 LSA) with everything else being stock except the lid and cut out, and i gained 22rwhp and 10rwtq, (everything else was stock, no headers, LS1 intake, no tune, stock rev limiter) but after the stage 2 heads, LT headers, LS6 intake, tunning, i gained another 75rwhp and 61rwtq over the cam only results (on the same dyno).
if you don't tune it, at least raise the rev limiter, ( i shift at 6400-6500)
hope that helps,
Abdulla
Old Apr 15, 2004 | 03:01 AM
Jason99T/A's Avatar
I can shift faster than you.
We typically see 35-40rwhp with the addition of the TR224/112 (or 114) on cars that have all the bolt-ons. I would recommend getting some sort of tuning to bump your revlimiter to 6600rpms to take full advantage of the cam.
Jason
Old Apr 15, 2004 | 05:28 PM
zyal8r's Avatar
Thanks for the help, That will definitly be my cam!
Old Apr 15, 2004 | 09:57 PM
enginjoe's Avatar
See signature. Agree with above.
Old Apr 16, 2004 | 01:29 AM
Krab's Avatar
Another satisfied TR 224 owner here! I've got mine on a 112lsa and she put down 376rwhp/rwtq earlier this week with the mods in my sig. I still need an LS6 intake too, so I'll see a few more ponies once that goes in. It sounds really good on a stock tune (nice and lopey), but smoothes out some after you get it tuned. There's definetely a noticable gain in the mid/top end even before tuning.
