Disappearing Horsepower
LS6, ported heads, 2.02/1.60 valves Isky 295's, vararam intake, LGM headers, magnaflow x pipe, borla stingers, no cat's, TNT wet kit, 3:42 gears, F1 cam 230/226 592 569 112.
The car pulled
426 rwhp 408 rwtq. Motor
538 rwhp 578 rwtq. 100 shot
Fast foward 3 months.
410 rwhp 397 rwtq.
Decided to make a few changes. Replaced cam with a comp cam
232/236 595 601 114, 3.90 gears.
395 rwhp 373 rwtq motor
492 rwhp 510 rwtq 100 shot
The car still feels strong. No codes, tuned by Chris R.
Tonight I performed a compression check.
1 185
2 180
3 185
4 187
5 180
6 185
7 185
8 185
This was with 4 compression strokes. After 8 strokes they were around
210 each.
Pulled the rockers and push rods, no problems. Tomorrow will be the leak test.
After that what??
So much for the train of thought that a "nitrous cam" needs to have more duration and lift on the exhaust side.
You can have two different cam profiles and they will show different cranking compressions in the same engine. This is due to variation in valve timing events.
Check back in after a leak down test!
Cyl Comp Leak
1 185 28%
2 180 10%
3 185 10%
4 187 6%
5 180 18%
6 185 25%
7 185 6%
8 185 10%
The car is not using oil, only down on power according to the dyno.
I am going to reassemble the top end and perform the test with the engine warm.
Any thoughts??
The ones over 10% are the big problem. Sounds like the rings and cylinder walls are glazed over.
A re-ring job is the cure.
cheapest cure:
get the block align bored, honed, and decked, decent 3.905 pistons and rings, get the stock rods reconditioned with ARP rod bolts. New bearings all around, have the crank balanced, polished, or whatever it needs.
Problem solved, you now have a good motor, spray away.
Did you leakdown the motor yet? It's the number one causer of loss of power with no changes!
Wiredog, if you plan on spraying the car a lot. Now is your chance to build the motor to take it without hurting the motor.
Never heard any air through the intake or exhaust. Sure was trying to though
Ok so its time to forge the bottom end.
What are your opinons on a 382 stroker? With the new Eagle cranks it's only another 1000.00
What could I expect over stock cubes?
go with a good set of moly rings and build your bottom end strong for the juice, don't spare any expense.
strokers add torque and torque is a good thing, makes daily driving more fun.
any more ?'s just use the search button.
I have not been too impressed with the 382 strokers. To make these motors run you really need to unshround the valves by opening up the bore size.
