How to identify a G5X2? Works w/o flycutting right?
Old 04-17-2004, 03:28 PM
Relativelyfast's Avatar
Default How to identify a G5X2? Works w/o flycutting right?
I'm hoping to buy an LG G5X2 232/240 .595/.609 112 lsa from "il corvette giallo." How can you be sure you are getting the cam you are paying for? Is there a code on it?
I understand that this cam will not require flycut pistons in order to fit. Is this correct?
Thanks.
Old 04-17-2004, 03:37 PM
Ben01C5's Avatar
I am running the G5X-2 cam in my vette right now. There is now flycutting needed.
I believe the only way to identify the cam is to check the lobes or call Lou and see if they mark them in any way.
Old 04-17-2004, 03:48 PM
Beast96Z's Avatar
It should have "LG G5X-2/112 ground into the rear base. Yes it will fit as long as your heads aren't milled much.
Old 04-17-2004, 05:23 PM
Thank you for the replies, I hope I get the cam!
