Ms4 results
Now am quite happy with the results do to the bad gread of fuel. But at the same time iv seen guys inbthe state make 400+ whp with the same set up do u guys think that this is a good whp since iv been running on dyno dyamic. And what iv know that dyno dynamic tend to read less whp than mustang or dyno jet dynos.
And if there is any comment to reach the 400whp without upgreading the heads. Or does that whp figure is verry good. And could the clutch cause a drop whp and if I changed it can I get any gain
Ms4 with 111lsa
timing chain with spokrets.
Push rods and prc double spring valve.
ls6 intake .
K&N Filter.
bbk 80mm throuttle body.
Ls6 ported oil pump.
Racing fuel pump.
42ib injectors.
tr55 plugs.
!egr
stock ls1 bottom end, stock heads.
Car was tuned via EFI live. result was 386 whp with 385 tq on a dyno dynamics dyno. Now am quite happy with the results do to the bad gread of fuel. But at the same time iv seen guys inbthe state make 400+ whp with the same set up do u guys think that this is a good whp since iv been running on dyno dyamics. And what iv know that dyno dynamics tend to read less whp than mustang or dyno jet dynos.
There you go, just set it up so we can read it better for you
