Any problem if using PAC Beehive Springs with this TSP cam
I want to install Texas Speed LS3 229/236 .624"/615" 113 Camshaft in LS3 engine
I have a set of PAC Beehive Springs - .625 Lift (Premium)
145# at 1.800” / 358# at 1.175”
are they OK with this cam or should i go to double springs ?
thanks in advance
thanks in advance
I wouldn't recommend anything because I'm not a valve train guy
. I would just make sure you have the correct pressure for the lobes your running and the installed height / distance to coil bind are correct. I'm like you and wanted to keep the weight down which is how I ended up with hollow/sodium valves and 1519's. the 1519's do give some extra pressure over the 18's if you need it. I'd call a couple reputable valve train guys and see what they recommend
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
