Is aftermaket heads worth going to vs. stock worked
#41
Heck, a fresh set of LS6 stage 2.5 Texas Speed Heads will run you $1600. That's with dual valve springs, and setup perfect for the trunnion upgrade. Or if you have a set of 243's to send in it will be something like $400 less!
In you est. cost, don't forget, head gaskets, header gaskets, intake gaskets( may not be needed), pushrods, spark plugs (mine as well), and tune.
I'm sure Jake Fusion is about to chime in here, I just started the infamous ported head war; TSP v AI v WCCH v TEA. Here we go......
#42
PM sent....just installed Livernois STG 3 243 heads....below is a list of everything I installed with the heads:
STG 3 243 heads (milled .012 just to ensure heads were true - app. 63cc chambers)
GM MLS head gaskets
ARP head bolts
LS7 lifters
GM lifter trays
7.375 push rods
comp trunion upgrade
FAST 36 lb injectors
GM MLS head gaskets
ARP head bolts
LS7 lifters
GM lifter trays
7.375 push rods
#43
yea cant forget about all that little ****, i was just adding in all the parts i knew i would use for either of the heads, im just glad my tuner is just down the street from me. I just need to find a head to head comparison on the 243s worked and the tfs220s and then maybe that will make my mind up
#44
Just looked around a bit further, apparently if you shim the stock rockers and use the PM guides it will work but it is not recommended by TEA or TFS. It will void the warranty from TFS aswell. The TFS 220 as cast seem like a great buy IMO, i also considered them. Your goals are very low, OEM cast should be more than enough. If i were you id pick up the phone and have a chat with TEA, or AI, or even texas speed which ever company you are considering and ask questions. Im sure TEA has dealt with enough TFS heads that they are qualified to tell you what is recommended and not and how it will do against an OEM cast setup.
#47
https://ls1tech.com/forums/dynamomet...-gm-5-3-a.html
Just something I like to throw out when folks talk about how aftermarket heads are automatically superior.
When shopping for parts look for results with reviews and look for cars that run "better than they should" meaning if 2 cars run the same ET but one has an extra $1000 in heads and is 150lbs lighter then which setup would you want to copy?
#50
Look under the Grand Prix GTP 36# Injectors at our base fuel pressure they are 40lb injectors+. They can be had on ebay for less than $150 for a set of 8. Ive seen people find them for $76-80 for 8.
Check out this thread.
https://ls1tech.com/forums/fueling-i...injectors.html
Or you can have your stock injectors Resized for $200 or so as stated by a sponsor in that thread.
#51
ok another thing i have been reading is flycutting, i dont want to have to flycut. the TEA stage 2s have slightly bigger valves than the AI 232cc heads and i plan to mill the heads but not sure how much to mill them. seems i will have a limited choice in the cam options, how can i get away with not flycutting
#54
Have who ever your getting a cam spec'd from spec out a cam that won't have any P2V issues. IMO, id check regradless before buttoning everything up.
Thanks Kevin I could not have explained that any better and you are 100% correct. On all the testing we have done running a roller rocker is the best option when getting into the higher lift cams. There are custom shops out there that will install powdered metal guides for you as an option but you will still void any warrenty by running the stock rockers.
Gregg
Gregg
#55
what gains would i have if i did get the heads with bigger valves, if its not a big gain and only like 5 hp then i would just go with the AI ones that way i have a less chance of flycutting and getting a little bit bigger cam
#59
what cam bolts would be recommended and how much should i get the heads milled down to so i dont have to flycut and it looks like im going with the AI 232cc heads for sure, i think they would be my best option.
