Best Driveability 230 Duration Cam
Old Jan 7, 2013 | 10:54 PM
95mysticta's Avatar
Default Best Driveability 230 Duration Cam
Planning a cam only swap want some feedback from some people on the board about what cams there running that still have great driveability without any surging and bucking. Looking at cams in the 23x/23x range. If you could post up your other mods, power numbers, and mpg would be very helpful
Thanks in advance just came to the darkside owning lt1 cars for the last 10yrs.
Old Jan 7, 2013 | 11:29 PM
1nasty86's Avatar
Turd Gen Guy
I have a friend with a 231/238 112+3 lsl/lxl cam.... has great drivability and good mpg... makes over 415 hp basically cam only
Old Jan 8, 2013 | 06:18 AM
TeEnAgE pHeNoM's Avatar
My friends car has a 231/234 112+2 LSL/LXL lobes. It runs 11.40s with stock 241's milled .030. Full weight car. The car makes crazy power under the curve. I tuned it and it drives good and gets pretty good mpg for a modded car.
Old Jan 8, 2013 | 07:56 AM
HCI2000SS's Avatar
All my mods are in my sig, and I run a V2 Torquer cam. Personally, i'm very happy with it...nice choppy idle, great drivability down as low as 1500 rpm, and strong mid range and top end punch
Old Jan 8, 2013 | 09:00 AM
Sales@Tick's Avatar
Any of the Stage 1-2 Torque Max cams or Street Heat cams we have will drive very well and be very easy to tune.
Old Jan 8, 2013 | 02:11 PM
arock24's Avatar
Your tuner has more to do with your drive ability than the cam does
Old Jan 8, 2013 | 10:13 PM
hiltsy855's Avatar
Listen to Martin, he knows his stuff.
Old Jan 8, 2013 | 10:50 PM
studderin's Avatar
I had a 236* streetsweeper cam, ran 10.6's 128 and made 425-430 cam only. Drove great on the street. No surging ever, no stalling, anything, Good tune is a must, not sure MPG, but put 2,200 miles on it one weekend, and raced it.
Old Jan 8, 2013 | 10:55 PM
JPH's Avatar
JPH
Use something in the LOW 230 range and use 113 LSA. Can't go wrong here. And having a "top notch" tuner works out even better.
Old Jan 9, 2013 | 09:12 AM
Sales@Tick's Avatar
Time to update that signature with the new parts!
Old Jan 9, 2013 | 09:20 AM
thunderstruck507's Avatar
230/238 113+2 here. I'm an amateur tuner and still have got it daily driveable.
So far it's ran 11.7@115 in ~1400DA at 3650lbs, gets around 19mpg highway.
Old Jan 9, 2013 | 08:48 PM
TXZ28LS1's Avatar
exactly!!!!
Old Jan 10, 2013 | 08:42 AM
TT427's Avatar
Are their any programs that calculate DCR using SCR and cam timing? If so, how big could one go and retain stock like DCR?
Old Jan 10, 2013 | 11:49 AM
PREDATOR-Z's Avatar
anything up to 9* overlap is good for stock cubes.
Old Jan 10, 2013 | 02:44 PM
Ronny_02_WS6's Avatar
Thunder Racing TRAK over here, 231/234 112 LSA, My tuner put it like stock.
