My reverse split tr230 cam and budget heads?
Old Jan 14, 2013 | 01:43 PM
lusting4ls1's Avatar
Default My reverse split tr230 cam and budget heads?
I know this cam was designed around stock heads and intake, so would putting a set of budget heads on only see minimal gains?
Heads in question would be AI 241 219cc hc, AI 243's, PRC ls6 stage 1, or PRC 5.3 2.5s.
Now I know ported 243's will outflow 241's, but it seems like they are really close in power and the smaller heads may be better for low and midrange? I also wondered if the reverse split would actually accommodate the smaller AI 241's or the 5.3's better.
My car doesn't live a 6k rpms and power in the driving around town range is important. I'm not interested in swapping out my either, for all the reverse split haters lol. But I don't want to only pick up 10hp in the upper rpm rand either, so I'm trying to figure out if the cost is worth it with this can.
Old Jan 15, 2013 | 09:09 AM
PREDATOR-Z's Avatar
AI 219 program will be a nice addition. Shoot for 11:1 Compression and do not go over 8.5DCR. You should pick up a good 30rwhp across.
Old Jan 15, 2013 | 11:42 AM
Thanks Predator, I was hoping you would chime in being the king of the reverse split cams.lol
Old Jan 17, 2013 | 03:48 AM
PREDATOR-Z's Avatar
I like what they do in the power curves I use.
