Replacing my 5.3 crankshaft what needs to be done?
Well I believe I have to replace my crank due to damage from too much endplay scoring the bob weights...unfortunitly I bought it this way.
my Question is if I buy another good used crank do I need to have the bottom assembly balanced? Im not sure how the LS's are balanced out at the factory
Thanks....thats exactly the info needed...that will help my search in figuring what I will have to spend to get it back together...I almost bought a one out of a 6.0 yesterday so I guess I will wait and see if I can find one from another 5.3 keep my cost down
In reality, it's not that expensive to have it balanced. It cost me 148 to have mine balanced. Even in a stock engine, it can have benefits. Factory engines are mass balanced. Meaning they all use the same balance for each engine, not each rotating assembly balanced.
I've seen stock engines as much as 40 grams off balance. That's quite a bit. A good balance can make more power, increase bearing life and make idle quality better. It can also make tuning easier if you ever decide to add some pep to it.
