Time for some winter upgrades/suggestions
I know you want to stay within budget, but I would talk to someone that specs custom cams. They will be able to give you exactly what you want for a rpm range and for your power goals. If it was me in your shoes I would take my time and make sure that only high quality parts go inside my engine. A motor as nice as a LS should not be built with cheap parts. Plus it actually saves money if you do it right the first time.
I'm actually wrapping up my final tune this weekend and upgrading injectors, hopefully. I'm only about 1200 miles into my h/c swap. There's 2 other camaros with almost identical setups to mine locally and the auto put down 423/416..I believe the m6 was around 435/420ish. I have the same tuner as they did, so I'm expecting similar numbers.
with better flowing heads you can use a mellower cam.a torquer v3 mite make it with your current heads.if you get low mileage 243/799 heads do a valve seat leak test.consider a cam from Damian or EPS,or tick .check out Texas Speed for the parts you will need,they have good prices on parts.
Well those are the numbers Im looking for... actually a little better than my goal which is always better!! Is anything done to your heads or just factory ones bolted on? Does your set up look similar to what I have planned besides manufacturer brands and that I will be using the Torquer V2 instead of the V3? I am also going LS6 intake which I assume you have?
Stock ls6 intake and 243's just have a valve job. Have you purchased the v2 yet? If you're deciding between the two, the v3 will net you more hp and will still work with the 241's. I only invested in the 243's because I plan on going with a 370 eventually...but they can gain you about 20hp.
I think u can do better than the tqr v3 its got a lot more lift than id want to run on stock rockers. Plenty of people do, but not me. I liked the 228r I had and not only is it a more streetable cam, but easier on valvetrain and longer spring life.
Thanks for the input. I think Ive come to the conclusion that im going to go with the Torquer V2 and the rest of my upgrades but will go with some 243's. I do want to mill the 243's to get to a 11:1 c/r that way I can run 91-93octane. My concern though is PTV (piston to valve clearance). If I mill the 243's to reach that 11:1 should my PTV be ok running a stock gasket size? Stock rockers etc. I assume I will most likely only find the non-Z06 243's so I WILL NOT have the longer sodium filled valves. I might get lucky and find some but im going to go with the scenario that I will not have those ones. What do we think about the PTV at milling the 243's to achieve 11:1?
Id recommend taking a look at the Tick "SNS" torqueMAX Stage 2 Camshaft.
IMO better lobes then the Tqr V2 or V3.
http://www.tickperformance.com/tick-...r-ls2-engines/
Just a little update... Brought it to the tuner today for a street tune! Finished buttoning it up on Saturday and sounds fabulous! I cannot wait to get it back from the tuner and then hopefully get a good couple rain showers and the street sweepers out so I can bring it out. I went with everything that is in signature below my posts. I went a little above and beyond and didnt cut corners... I paid the $$$$ to do it but I know its worth it to get it done.
