People w/ EPS cams, post your setups
Old Jan 17, 2013 | 12:43 AM
LilJayV10's Avatar
Default People w/ EPS cams, post your setups
I was going to post this in the dyno section but I thought it might get more views here.
I know EPS cams are popular on here and have read how bad Comp Cam's quality control is.
I'm wondering if anyone is making big numbers and going fast down the track w/ EPS cams.
I'm just curious to see what others are getting out of their setups.
Thanks!
J
Old Jan 17, 2013 | 06:40 AM
low2001gmc's Avatar
MASS seller approved
theres some dyno graphs on the eps 226-234 in the dyno section where with ai or tea 243s have done like 460-470 hp so with a 3600 stall and some 3.73 or 4.10s, you know theyre gonna boogie on down
Old Jan 17, 2013 | 09:31 PM
98blueSScamaro's Avatar
346 ci ls6 block
stock pistons
stock rods
stock crank
243 heads Cartek 4X milled down to 56cc chambers
eps cam
and bolt on's
T56 trans
ford nine with 4.56 gears
hoosierQTP 28x11.5x15 tireon the dyno
made good power 495 RWHP 430 RWTQ and has made more just cant find my dyno graph.check post 3 for one graph i can find.
https://ls1tech.com/forums/dynamomet...c-inch-na.html
Old Jan 17, 2013 | 09:48 PM
_GTO_'s Avatar
Actually , Comp cuts EPS cams .
Old Jan 17, 2013 | 10:11 PM
LilJayV10's Avatar
I know that. That's why I worded it the way I did. It sounded right in my head anyway.
Old Jan 17, 2013 | 10:15 PM
LilJayV10's Avatar
I have a EPS 226/230 cam w/ TEA heads, ported FAST 92, LT's, etc. It did 430hp/420ft lbs with really bad valve float(machine shop set the install height at 1.81 instead of the 1.72 it was suppose to be at) and a slipping clutch. Since I have fixed all the issues the car is way faster than it was when it was dyno'd. I'm either going to get it retuned or learn how to tune it myself.
Old Jan 17, 2013 | 10:39 PM
What tea heads they offer a wide spec.
Old Jan 17, 2013 | 10:48 PM
LilJayV10's Avatar
5.3 stage 1.5, milled to 59cc.
Old Jan 18, 2013 | 12:19 AM
Rybar's Avatar
99 Trans Am, 346 LS1, T56, EPS 222/226 114 baby cam, CNC ported 243's, .040 Cometic HG, LS6 intake, ported TB, 42# injectors, Kooks LT's and True Dual system and it made 424/412 on a Mustang Dyno.
In my 69 Camaro I have a 383 bottom end going in with an EPS 235/242 638/615 113 I will post results soon.
And my buddy just put down 499/463 cam only C6 Grand Sport LS3 with a 226/234 114+2 .598/.612
Old Jan 18, 2013 | 07:03 AM
Brennen's01SS's Avatar
First build:
01 Camaro SS
Ls1
Prc ls6 2.5 62cc
Eps 226/234 .598 .601 113+2
Fast 102/102
M6
451/398 dynojet at eps
Latest build:
01 Camaro SS
Sdpc Ls3 416
Tea trickflow 245 65cc
11.3 comp
Eps 243/251 .628/.631 113+2
Fast 102/102
Gzmotorsport vac pump 9"
M6
560/480 same dyno
Old Jan 18, 2013 | 09:11 AM
thunderstruck507's Avatar
stock 98 shortblock
799 heads: intake valve bosses cut down and smoothed, rocker boss removed, full sanding on intake and exhaust runners with 80grit, 120 grit on exhaust, no exhaust side porting
EPS 230/238 113+2
FAST 90mm, runner bump removed
GM 41.5# injectors
Doug's 1 3/4" Chevelle swap headers with a couple dents in some primaries
GM 85mm MAF
4" inlet cone filter on a 90* duct into the TB
underdrive pulley
stage 2 4l60e with Yank SS3600
heavy chromoly steel 3.5" diameter driveshaft (56" long)
12 bolt with Eaton and 3.42 gears
tuned by me, 27* timing and 12.6-12.8 afr
Best pass so far was: 7.50@93mph, 11.78@114mph on a 1.72 60ft in ~1400DA
Runs identical times (with slower 60ft) as a local 2011 5.0 manual car that made 412 rwhp (x pipe, boss intake, tune)
Old Jan 18, 2013 | 09:25 AM
BKsNHRA's Avatar
Psi 1511 springs
eBay longtubes
Tsp y pipe magnaflow cat back.
3.73
Everything else stock as it gets
380hp 373tq.
I believe it has a lot more in it
Went 12.82 at 110 with a 280lbs driver and really bad traction and wheel hop issues.
Old Jan 18, 2013 | 09:37 AM
Grr's Avatar
Grr
Old setup
Stock ls1
243s ported by me, 12.9 compression
EPS 238/246 111+3
BBK 1 3/4 headers 2.5" y and 3" borla exhaust
stock LS1 intake and TB
stock 4l60e with a 3800 stall
ran 120mph consistantly with low timing and shifting at 6000 (cam is supposed to run to 7400), 34xx# car or around 445whp
New setup
14:1 378" LS3,
same 243's,
same EPS 236/248,
super vic/4150
changed to a LS3 shortblock and a super victor, thats it. Looking for over 550whp
Old Jan 18, 2013 | 09:59 AM
Camaro Z's Avatar
Eps 230/234 .600 .602 112+4 LSA
Stock 241's
1 3/4 long tubes
ORY
Cut-out
4.10's
Stock injectors
Full weight minus drag wheels.
T56
Best 1/8 mile time 7.41 @ 94 1.60 60ft. 500-600 DA
TEA 5.3 heads and 42# injectors going on shortly. Hoping for some 7.10's-7.20's @ 96-97 with the new heads and retune.
Old Jan 18, 2013 | 03:16 PM
bene's Avatar
Trunion King
EPS cam 222/226, 113 LSA with stock 243 heads/stock MLS gaskets, full exhaust, UDP, lid, p/p TB, 85mm MAF, LS6 intake and a tune.
Dyno Dynamics dyno, 440 rwhp.
Old Jan 19, 2013 | 08:55 AM
A.R. Shale Targa's Avatar
Smallest EPS checkin in here @ 218/226 .595"/.598" 117 +3
365/344 w/DIY 241s and shorties through M6.....currently estimated @ 380
since swapping to long tubes and 3" hi flo cats....3400 lbs....11.87 @ 119.85
Old Jan 19, 2013 | 03:57 PM
LilJayV10's Avatar
Thanks for replies guys. It's good to see the EPS stuff putting out good numbers and times. After I get my car lined out I hope to run bottom 11's but we will see. I'm definately considering buying HP Tuners or EFI Live and learn to tune it myself.
I have also considered ditching my set of XS long tubes for a set of 1 7/8 ARH's or Kooks but I don't know if I will pick up anything or not. It's amazing the information on the 1 3/4 and 1 7/8 header debates on here. Some swear its worth it others don't. I guess it really depends on each setup.
Old Jan 19, 2013 | 05:34 PM
fly boy_1's Avatar
I've got an 02 Z28 with a EPS 230/234 .600/.601 111+3 LSA. Longblock is stock aside from valvesprings and UDP, also had a dual exhaust and a SLP lid. Made 390/350 on a mustang dyno last summer when it was tuned. Made 355/347 with the stock cam. Drivability is only ok.
Took it to the track and ran a disappointing 13.3 @ 113-114mph...
Old Jan 19, 2013 | 07:20 PM
LilJayV10's Avatar
Definitely sounds like something is off somewhere.
Old Jan 19, 2013 | 07:34 PM
Mike Morris's Avatar
Ran low 11s with stock heads,stock wheels,all sway bars on at full weight with 3800 stall. MPH 117
