Low oil pressure after warm
Old Apr 26, 2004 | 08:55 AM
mikez28_mjf's Avatar
Originally Posted by WMSuperSport
Mikez28, mine does the same, how long have you been driving around like that?
I plan to replace the sending unit, and if that doesn't help I'll replace the pump and o-ring, and if that doesn't help-it looks like a rebuild. Anyone know of any job openings in DFW?
When I noticed it...probably around 10k-15k miles ago. about 2 years. I don't drive my car much. It's been to the track several times and I added my converter in that time. my car has 88k on in it now.
Let me know how changing that stuff goes.
Old Apr 26, 2004 | 11:19 AM
Z28GSXRTim's Avatar
What is 'normal' psi for these engines? I had my engine rebuilt over the summer and I never paid attention to what the oil pressure was before and after. With Mobil 1 5W-30, it was 25-30 psi at idle and would drop to about 20 psi when I would let the clutch out and no more than 45 psi at WOT 6k RPM. I just changed it to Mobil 1 10W-30 this weekend and it is higher, around 45 psi on cold startup, around 35 psi at warm idle.
Can anybody recommend a good place for oil analysis? I'd like to do that in a few thousand miles just to check for a spun bearing or anything.
Old Apr 26, 2004 | 12:49 PM
WMSuperSport's Avatar
I'd also like to know...
Old Apr 26, 2004 | 01:17 PM
2001 HD's Avatar
Default Blackstone-labs.com
Blackstone-labs.com
May get edited since they are not a sponsor.
Offer free test kit. $20.00 for standard analysis.
Old Apr 26, 2004 | 02:42 PM
stealth's Avatar
After the car warms up I get very little oil pressure. It seems to be getting worse over the past year or so. Has anyone else had this problem and fixed it? Thanks,
Wes
Could be too much bearing clearance.
Old Apr 26, 2004 | 02:47 PM
Thanks 2001 HD, I'll give that a try.
What's the worst that could happen with too much bearing clearance and low pressure?
Old Apr 26, 2004 | 03:55 PM
Z28GSXRTim's Avatar
Just another thought- I am using a Fram oil filter. What is everybody else using, especially the guys with the low pressure? What is recommended?
Old Apr 26, 2004 | 07:08 PM
zamboxl's Avatar
this is just something that i have been told never ever use fram with this car go with k&n or some other long filter like that.
Old Apr 26, 2004 | 07:16 PM
Z28GSXRTim's Avatar
Hmmmm, interesting. I've heard that before, but thought nothing of it. Well, I will change the filter for an AC Delco or something and see what happens then. Hopefully that will cure my problem.
Old Apr 26, 2004 | 08:09 PM
soundengineer's Avatar
as long as you have 10ps1 / 1000rpm you will be fine
mine sits just below 40 at idle...and goes up to almost 80 when I am up at 6500rpm...
and I have noticed it sits a little higher or lower depending on filter....right now I have on a fram..
Old Apr 27, 2004 | 08:31 AM
Z28GSXRTim's Avatar
That's just it- I am only seeing a max of 45 psi at WOT @ 6k RPM.
soundengineer- what mods do you have done to your car?
Old Apr 27, 2004 | 08:36 AM
  #32
CHRISPY's Avatar
Some obvisou things to check
- check your oil level. Make sure your arent running really low
- change your oil and run an AC delco filter. Check the plug for shavings
If that does nothing look at an oil pump replacement.
did this happen right away or over time after the swap?
Old Apr 27, 2004 | 09:05 AM
  #33
zamboxl's Avatar
just make sure it is a longer filter, it will help your oil presure, by giving you a better flow.
Old Apr 27, 2004 | 12:18 PM
  #34
Chris, my level is fine and it seems to be the same no matter what filter I use. My pressure has progressively gotten worse over the past year or so (I'm guessing I only put about 5K on my car the past year) and I've used Fram, AC Delco, and now a WIX. Once warm I get almost 10 psi at idle and near 40 at WOT.
Has anyone ever heard of an oil pump to start loosing pressure like this? I thought they just quit working all together...
Might switch from 10W-30 to 15W-50 or something like that.
Thanks
Old Apr 29, 2004 | 05:39 PM
  #35
rspect's Avatar
Quick question. I am showing these same indications but my question is are you running hot. I removed my radiator cap and cranked the car and noticed that the water did not move. Believe I might have to replace my water pump and thermostat and believe that is what is causing my low oil pressure after it gets hot. What do yall think???
Old Apr 29, 2004 | 09:20 PM
  #36
ss rally red's Avatar
02 SS, 21K, idles at 50 psi, 2k-25 k 60psi 3K and above runs at 65 + tops out at 70 plus, I run Mobil 0W40.
Old Apr 29, 2004 | 10:57 PM
  #37
heads - 5.3L stage 2
cam - MTI X1 230/227 .591/.571 112lsa+4
Manley Springs / Titanium Retainers / Hardened Pushrods
LT headers - hooker 1 3/4" with 3" collectors
True Duals - 3" with Xpipe
LS6 intake
LS6 pcv mod - still have a catch can for the just incase factor...
no egr-no air
no AC
short belt
160* t-stat
ported polished TB and MAF
Lid
K&N
Tuning By Raging Motorsports
Road Pirate Subframe connectors going on soon
91000 miles...still on the stock clutch...and it still grabs great
pulling the engine to 6500-6800 at the track
made the numbers in the signature...befor the LS6 stuff...before heads....with power steering belt on and AC still connected
gotta retune here in a few weeks after some $$$ flow....will have new #'s then...expecting 430+ HP and 400+ TQ
still need to get a 12 bolt..a spec stage 3 clutch.... and a cage....and some slicks for the track...and a DS Loop...plus some suspension stuff and a pulley...
pulled a 12.7 @114 on street tires
went 11.7 on some borrowed slicks...cant remember speed...got kicked off the track for no cage and no DS loop
Old Apr 30, 2004 | 12:35 PM
  #38
My car stays ~ 180*
Old Mar 4, 2005 | 07:03 PM
  #39
toyjet2000's Avatar
I was reading old threads
Did you ever figure out your problem?
If so what was it.
Thanks.
On startup oil pressure is about halfway up the guage, then once warm (a few minutes later) it will drop closer to the red than 25psi. I would guess around 10 psi or so at idle. At WOT is doesn't even reach 25 psi.
Thanks for the help,
Wes
Old Mar 5, 2005 | 09:42 AM
  #40
Nope, never figured it out. I just replaced my stock oil pump and now I get alot higher pressure, but it still goes down after the engine warms up. I'm building a whole new engine now.
