Low oil pressure after warm
Wes
EDIT: Did an oil analysis and that showed everything was normal so I replaced my stock oil pump (55K miles) with a TSP ported and switched to 15W-50 and my pressure is great, even after warm. I also replaced the O-ring which looked a little worn but I wouldn't have blamed it as the culprit. When warm I see ~45psi at idle and ~70psi at WOT. Thanks guys.
Somebody else chime in....I'm no expert.
Thanks for the help,
Wes
Thanks
I currently use Valvoline SynPower 5W-30 ... on Patman's recommendation I am gonna switch over to Mobil 1 0W-40 ... supposedly a better oil choice for the LS1.
If you are only pulling 25 psi of oil pressure at WOT, you need to quit driving your car NOW and replace the oil pump at a minimum. You may have also trashed one or more of the bearings with that little oil pressure at WOT...you should be pushing at least 60+ psi at WOT.
Once I'm back and the highway @ 60mph it runs about 38-42.
I plan to replace the sending unit, and if that doesn't help I'll replace the pump and o-ring, and if that doesn't help-it looks like a rebuild. Anyone know of any job openings in DFW?
