single row adjustable timing sets
Old Jan 22, 2013 | 11:15 PM
ckpitt55's Avatar
Default single row adjustable timing sets
I know this has probably been hammered to death but didn't have much luck with a search.
Is there anyone who makes a single row adjustable timing set with a torrington bearing, preferably with the adjustment on the cam gear? I've already got an LS2 chain so if I could just buy gears that would be a bonus.
Will consider double-row sets if I have to but I don't really want to deal with timing cover interference issues. I'll be running the ported LS6 pump from tsp.
Thanks in advance for any help.
edit: came across the cloyes hex-a-just sets, anyone using cloyes pn# 9-3158A?
Old Jan 22, 2013 | 11:29 PM
FAD2BLK93's Avatar
Doesn't TSP have the Cloyes single row hex-adjust? Look through their catalog...they have a large selection of sets.i think the hex will take the slack out? Thats what i want. Or do u go to oversized gears? Someone enlighten me please.
Old Jan 22, 2013 | 11:32 PM
badassracing's Avatar
The hex-a-just is for degreeing the cam. The cloyes gears are made oversized to take out the slack. They do come with a thrust bearing.
Old Jan 22, 2013 | 11:45 PM
ckpitt55's Avatar
sounds like everything you could want then. i'm assuming that the cloyes chain would be sufficient for 450ish rwhp?
Old Jan 23, 2013 | 12:22 AM
RonSSNova's Avatar
I'm using the Cloyes. The chain is by IWIS. It is nice and tight when installed. And, you can set the cam timing. It's a nice set.
I've been hotrodding Chevys both small and big blocks for 35 years, and never used anything but Cloyes True Roller timing sets.
Ron
Old Jan 23, 2013 | 05:07 AM
Gray86hatch's Avatar
I have a 1x single row with thorrington bearing Rollmaster for sale.
It is new in the box I am thorowing in a ls2 dampner
has the IWIS chain, billet gears 9 way adustable
I am switching to 4x is the reason I need to sell it.
Tim
Old Jan 23, 2013 | 05:27 AM
